  New Posts New Posts RSS Feed - 1972 Ranchero - air plenum side weather seal
andrewok1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewok1 Quote  Post ReplyReply Direct Link To This Post Topic: 1972 Ranchero - air plenum side weather seal
    Posted: 16-March-2023 at 8:15AM
i have bought them for my projects ,on ebay
 i used a rubber tire tube and i bent a piece of sheet metal and made the flap that way
 it also keeps the air from rushing up your dash vents
GET IT GOT IT GONE !!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewok1 Quote  Post ReplyReply Direct Link To This Post Posted: 02-June-2015 at 10:24PM
Originally posted by aussie_dave aussie_dave wrote:
Ah no they are at the very sides of the plenum. Small openings to allow any water to run out down between the inside of the fender and the firewall. I have those top grates, thank you for the offer.
The seal or rubber flap has a metal holder over the top section to hold it in place and 3 small phillips head screws to hold that in place. It would only be about 3 inches long and 1 inch tall... the hole that this flap covers.
Hopefully that clears up the desription and location.
Davud.
                                                   I have one nos dave and I found them on ebay.iwill get you the part #  andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 29-May-2015 at 2:30PM
picture of the ROTTED what was left of the passenger side of the yellow one I stripped.
It had a metal hold down plate the rubber was formed to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 29-May-2015 at 11:22AM
Is this the flappy thing on the side of the cowl?
aussie_dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aussie_dave Quote  Post ReplyReply Direct Link To This Post Posted: 29-May-2015 at 10:21AM
Yep thats what l thought too just make two.
Thanks for your reply.
Cheers David.
David Dare
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 29-May-2015 at 10:03AM
yup, I know what you are talking about now... nope don't have any.
In reality you don't need it if you don't daily drive in the rain.
It is there to keep road spray around the wheel well skirts from going up into the cowl area and to keep critters out. then it lets the water flow out to drain.
A piece of screen and a small flap of rubber and you can make something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aussie_dave Quote  Post ReplyReply Direct Link To This Post Posted: 29-May-2015 at 9:54AM
Davud.
David Dare
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 29-May-2015 at 6:12AM
I'VE GOT A STACK OF THEM.
starsky460 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote starsky460 Quote  Post ReplyReply Direct Link To This Post Posted: 29-May-2015 at 3:43AM
Carl
1976 Gran Torino Starsky & Hutch Limited Edition
FACTORY 460 c.u. engine
3:55 gears
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 29-May-2015 at 1:19AM
Dave are you asking about the plastic grate/covers that go over the holes where you get inside the cowl to access the Windshield Wiper stuff?
IF so, I can grab a couple of them tomorrow while I am at the farm.
Pay the shipping and couple bucks and they are yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aussie_dave Quote  Post ReplyReply Direct Link To This Post Posted: 28-May-2015 at 11:35PM
Its time for a bit of work on the outside, now that l have most of the inside in place, the guards/fenders ... have a weather seal hidden within them for the air plenum just below the windshield, there are two, one on each side, does anyone know where they are sold, l have scoured everywhere for two of them!!!   Thanks in advance David
David Dare
