Sand Blaster |
NorthElite ![]() Member ![]() Joined: 22-February-2015 Location: Finland Status: Offline Points: 195 |
![]() ![]() ![]() ![]() ![]() Posted: 21-September-2015 at 11:56PM |
With larger parts local metal shop help me with professional sand blasting tools. With smaller parts I have sand blast cabinet. This came with vacuum cleaner, so it keeps dust inside in it. I run it with 8hp compressor. Sand blast cabinet works well, but It does not make any miracles. With heavy rusted parts I use acid dipping to help getting rust out.
![]() ![]() I have one of these dual blasters too. It works with soda and sand, but my compressor is too small with it. I can only sprayed lots of sand or soda, but nothing is happens with it ![]() |
swampbug ![]() Member ![]() ![]() Joined: 19-August-2015 Location: South Carolina Status: Offline Points: 130 |
ive been reading on it. Just enough air pressure to do the job, different media have different % of inbed. Don't stay on one spot too long, friction will raise temp, warp metal
lynchster ![]() Senior Member ![]() ![]() Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 2126 |
I've used iron oxide but that's dangerous especially if you've never done it. The most important thing is distance and movement because warping sheet metal is easy. |
72 Gran Torino Sport 08 Taurus (Maytag) 03 Dakota (Rusty) |
what do you use for body parts? glass/soda?
legend onirot ![]() Senior Member ![]() METAL GOD Joined: 18-January-2009 Location: hattiesburg ms Status: Offline Points: 3033 |
i bought a 100 pound sandblaster similar to the eastwood one.
chuck is right, the air compressor is important. i used a 40 gallon married up to a 5 gallon air compressor. still was slow, just have to take your time. the hose on mine eventually wore through. i had oreillys cut me a power steering hose about 6 foot. works great. the ceramic nozzles are replaceable and cheap. the valves are easily replaceable, you can buy them at lowes or home depot. i did all my sandblasting on stacy lynn with this sandblaster. the frame, suspension parts, under the body, etc. (dont sandblast body parts with sand) i think i paid around $100-120 but that was 5 or 6 years ago.
malcolm 1973 gran torino sport (formal)... "Stacy Lynn" 1972 gran torino (formal)... "Mackenzie" 1973 gran torino sport (sportroof)... "Leela" |
How is maintenance on this? Hose get abraded quickly? Replacement nozzles?
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14468 |
here's the one i have: (think i paid $39 or $49 for it about 20 years ago)
http://www.sears.com/craftsman-50-lb-sandblaster-kit-with-1-4-in/p-00916706000P |
http://www.eastwood.com/eastwood-50lb-pressure-abrasive-blaster.html
so these are the types to choose from? pressure or syphon? Edit: Also looks like a gravity feed blaster as well. So which is best for stripping paint?
Edited by swampbug - 01-September-2015 at 5:01PM |
i too have a small 40#? craftsman from sears works great! but is a little slow for big jobs like the entire frame, it will blast it fine , just takes longer.
cabinets are great but unless they are large, you can only fit smaller parts in them (brackets and maybe a wheel) they do make bigger cabinets=bigger price ![]() then you have the pressure pot type they are good for frames, but can be a little harsh and powerful for sheetmetal like fenders (can warp the thin metal!!!) |
I bought a cheap 40 pounder and have used it to do the frame and entire underside of the car. I still have and use the hell out of it. First thing to do is ditch any brass fittings for steel. More important is your air compressor. I used an old Emglo (1977) 80 gallon tank with a 5 hp 220V compressor.
I've been looking at buying for my project. Ive seen stand alones, cabinet models, etc. It seems to me the best use for these is small stuff, since if I do body parts, Ill just be wasting the media. Any thoughts?
