1970 wiring issue?? HELP |
carguy47 ![]() Senior Member ![]() ![]() Joined: 08-October-2011 Location: Phoenix, AZ Status: Offline Points: 365 |
![]() ![]() ![]() ![]() ![]() Posted: 09-March-2016 at 4:00PM |
Hey guys. I just had an issue pop up without warning or prompting on my part.
I was driving home and the car started to sputter and finally die. I went to check the battery and I have NO power. I tried jumping the car and switched the battery. ZERO power anywhere! Two days later I had some time to work on it and it fired right up immediately? The issue seemed to resolve itself. However it ran for 5 secs - died AGAIN! ZERO power anywhere. Switched batteries and the headlights and interior light came on. I went to start the car and the battery sparked and ZERO lights again! I charged the battery again, no issues with battery. Four days later I put the battery back in and I had interior lights. I went to check the headlights and BAM... ZERO power again??? What the heck is going on? Any ideas? ![]() ![]() |
You have to build em to drive em!
Ranchero Fan ![]() Senior Member ![]() ![]() Joined: 03-March-2011 Location: Chicago area Status: Offline Points: 1022 |
Battery cable or cable clamp(if you have replacement cable ends)? I had a replacement cable end, on one of my cables, & after a short time decided to act up one damp night in the middle of nowhere.
Brian 1973 Ford Ranchero Big Block. ''THE OTHER WOMAN''
jversch ![]() Senior Member ![]() ![]() Joined: 25-March-2013 Location: Canandaigua NY Status: Offline Points: 323 |
Check all your power and grounds . Sounds like you have voltage drop when you put a load on the system . Even if it looks clean , cleaning them may fix it .
Jerry VerSchneider
1972 Gran torino formal roof H Code 1973 Gran torino fast back H code. |
Big Bird ![]() Senior Member ![]() ![]() Joined: 25-August-2013 Location: New York Status: Offline Points: 4162 |
I had the end rust off my starter cable right at the starter. Rest of car got power, until I cranked starter and the cable end arced and killed the battery. Couple hours later, I could repeat the process...
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14173 |
yes sounds like the battery cable either pos or neg, battery end or the other end somewhere
Spot on guys. I replaced and Cleaned ALL ground straps and bingo...car runs again. Thanks
