What do need for a Posi rearend?..Trac Loc |
mcford ![]() Senior Member ![]() ![]() Joined: 31-May-2003 Location: Utica, Michigan Status: Offline Points: 2160 |
![]() ![]() ![]() ![]() ![]() Posted: 07-April-2016 at 7:19AM |
ITLL BE 28 SPLINE.
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14555 |
yeah you'll need to buy some 31 spine axles
GoldFinger ![]() Senior Member ![]() ![]() Joined: 03-April-2015 Location: North Carolina Status: Offline Points: 295 |
Thanks,if it is 28 is it ok to go to a 31 spline?
DARE to be DIFFERENT!!
73 GTS |
yes that's what i did! probably the best way to go (with new carrier and bearings and seals) then you know it's good! also a good time to replace the axle bearings while it's apart
![]() you probably have a 28 spline in there now, you could pull an axle and count the splines before you buy! it should be either 28 or 31 splines. the place i got mine from doesn't have any at this time. but this is the closest i found new: http://www.ebay.com/itm/9-Ford-28-Spline-Posi-Unit-Trac-Lok-9-Inch-NEW/221873451647?_trksid=p2047675.c100040.m2060&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D35934%26meid%3D9e04a2052be44a74b01ec1f82ef38f09%26pid%3D100040%26rk%3D1%26rkt%3D4%26sd%3D221873451647 Edited by californiajohnny - 06-April-2016 at 5:20PM |
Can't I just by all the internal items since I have a 9 inch from the factory?
I have someone to do it for me once I get everything. |
73 GTS |
Thanks!
How many splines? Don't know much about what to buy or look for. |
73 GTS |
basically a good used 3rd member with the trac'lock and the gearing you want, pull the axles and swap the 3rd members
Well,the topic pretty much sums it up.My car came with a non posi highway gear.
While it is cool to keep up with everyone on the highway,I would prefer to step up with about a 3:73 gear. So with my rear tire and wheel size it will probably be run like a 3:55 gear.So besides a ring and pinion what else will I need to get? Edited by GoldFinger - 06-April-2016 at 1:47PM |
73 GTS |
