Where are the casting #s on 351w |
Posted: 19-August-2018 at 8:20PM |
numbers matching guys usually consider cast dates within 1 - 1 1/2 months before the vehicle assy date to be correct
what they said ^^^ olympia??? only olympia i know is in washington state!? if so i'm only about an hour south of you
Md1976
New Member Joined: 18-August-2018 Location: Olympia Status: Offline Points: 3 |
Yes defiantly helps knowing how to test the sensor, don't like buying un necessary parts. Thank you
Md1976
Would it be a matter of comparing the casting date to mfg date of the car? Thanks for info will hunt around for #'s
block cast codes can be deceptive as some codes run for multiple production years, the casting date will be more helpful. it's usually right below the block cast code near the starter. you'll see something like D4AE-BA that's the block code then below it the casting date code will look something like 6G26, then we can decode it
7T9_Tbird
Senior Member Joined: 04-December-2017 Location: Athens, Alabama Status: Offline Points: 495 |
If memory serves, they're on the driver's side of the block, back by the rear of it. As for the temp gauge, try grounding the sender wire to the block. If it jumps up, it's a bad sender. Otherwise, it's probably in the gauge, the printed circuit on the back of the gauge, or somewhere in the wiring. I'd check the gauges after the ground test, then the wiring. Hope this helps!
John
79 Thunderbird Heritage 79 Thunderbird Town Landau 02 Ram 1500 Sport Quad Cab |
Md1976
1976 gran torino, trying to see if engine is original to the car. Also having trouble getting temp gauge to work
