  New Posts New Posts RSS Feed - Few Questions
Few Questions
302ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 302ford Quote  Post ReplyReply Direct Link To This Post Topic: Few Questions
    Posted: 11-January-2009 at 12:51PM
Also quick question. I'm looking to buy new headers for the 408 setup and was curious if any one knows of a 1 3/4" or 1 7/8" primary that will fit these cars?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 302ford Quote  Post ReplyReply Direct Link To This Post Posted: 11-January-2009 at 12:45PM
As far as the coils...what rate are you running.
I know personally from dealing with a few guys, these cars need all the spring you can get.
Talking 700-850 pound rate springs...but be forewarned too much, and you got yourself a dump truck ride.
I'm running a 480lb springs out front currently with I believe 220's out back. I think I want to step it up a bit in the future though. The QA1 12 way ajustable shocks I have in now are absolutly amazing and would definatly recommend them. I can change my ride from a sloppy mess to a setting so stiff I dont even think my springs are even working.
Thanks for the info
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 06-January-2009 at 2:53AM
I still stand by my.
"big rims, small tires" poly bushings, big sway bars, small block springs (with a big block) and bilstein shocks.
The car is between my Z24 and my Truck for handling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 05-January-2009 at 6:19AM
Sway bars, you got it pretty much handled, front bar flip to bac works.
Book from a place called MRE has info on the fab to put a front bar out back, but it's pretty basic.
Have a good one
Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote 302ford Quote  Post ReplyReply Direct Link To This Post Posted: 10-December-2008 at 7:16AM
I'm sure the body roll would be greatly minimised if I just ran a 1 1/8 with a 7/8 but I just wanted to see what was out there before I thow down the money. I think I'll probably just grab a 1 1/8 now and chuck my current front bar on the rear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2008 at 12:45PM
Custom. Weld some brackets to the rear axle, and to the frame. Fab up some endlinks.
I'm surprised at the body roll you have.. I run the big 1 1/8" bar and the addco 7/8" rear bar and it's damn near flat.
Then again, I run 17" rims with 50 series tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 302ford Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2008 at 6:52AM
Thanks, I'll look into this. Is it more of a custom fab job or direct bolt in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2008 at 3:42AM
You could adapt a front bar to the rear if you wanted to tighten it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 302ford Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2008 at 6:17PM
Hey, I have a 79' LTD II that I'm currently in the process of building. I'm Stabbing in a 408 stroker and tko 5 speed in it to replace my built 302 and c4. Just Curious if anyone has managed to chuck in a cable operated clutch setup or if I'm stuck going hydraulic?
Also, I like taking corners in this beast and am quite confident in the car. I currently have a fresh Saginaw box, all new steering parts, stiffer springs, QA1 ajustable shocks and poly bushings thoughout. The only problem I have is the body roll with my current setup of a small 1" front sway bar. I'm curious if there is anything bigger I can use than a 1 1/8 front, and 7/8 rear I see online.
Thanks in advance
Chad
Edited by 302ford - 08-December-2008 at 6:20PM
