  New Posts New Posts RSS Feed - intake
intake
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: intake
    Posted: 03-July-2020 at 10:59AM
Is there a difference between a 84 truck and my 79 351w.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 03-July-2020 at 12:10PM
If you find a HO 351 in a truck around that era it should have a 4bbl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 03-July-2020 at 1:05PM
Add said mid 80 ford truck. Cast iron
will it work casting is54te9425 bb I believe. How you doing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 03-July-2020 at 1:24PM
If it is a 351 carb intake it will bolt on and work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 03-July-2020 at 1:56PM
Now if he will ans his add
Rons73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rons73 Quote  Post ReplyReply Direct Link To This Post Posted: 03-July-2020 at 6:05PM
E4TE 9425 BB Mine came off a 85 F150 4x4.  351W, 4bbl, cast iron with 4 hole style carb pad.
Should bolt right on Smile
