  New Posts New Posts RSS Feed - 351c 4v Fan
351c 4v Fan
Exodus BKG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Exodus BKG Quote  Post ReplyReply Direct Link To This Post Topic: 351c 4v Fan
    Posted: 06-July-2021 at 5:06PM
Electric Derale w/ Pulse Width Modulator.
Remove the mechanical burden on your motor of a Fan and or Fan Clutch.
I switched to electric a long way back, way better cooling controlled power. Less load on your motor.
Derale .c
They have all sorts of stuff
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 02-February-2021 at 3:26PM
I still have a flex fan on mine. 400 with A/C. I think it is 5 blade. Zero overheating issues on the hottest days. Then again, my evaporator needs to be replaced.
Fritz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fritz Quote  Post ReplyReply Direct Link To This Post Posted: 02-February-2021 at 6:26AM
Any advise to which fan would be best for my 72 GTS 351c 4v w/AC?
fritz
