  New Posts New Posts RSS Feed - Air bag suspension on 73 GTS
1973onirot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973onirot Quote  Post ReplyReply Direct Link To This Post Topic: Air bag suspension on 73 GTS
    Posted: 29-March-2021 at 3:01AM
Thanks for the info I really appreciate the help.
David G
1973 GTSF
1965 Falcon convertible
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 28-March-2021 at 2:45AM
This article from lowrider magazine in '04 may help, shows some pics of front shock relocation, just not in full detail. Hope it helps.
shanewherry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shanewherry Quote  Post ReplyReply Direct Link To This Post Posted: 28-March-2021 at 12:49AM
I am interested in this too. The front is a shock down the middle of a spring so you should be able to call ride tech for info on that. The rear would be just bags so you have to make mounts for the bags.
1973 Gran Torino Wagon
400/C6
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2021 at 1:28PM
If you can find one for a 65-78 ford fullsize, it should be a simple install,
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2021 at 4:48AM
It would be very expensive. Given there aren't any aftermarket parts made for the car, you would have to adapt available parts, and make a few as well. I'd say find videos of air suspensions being installed onto similar chassis types, and see what you can learn from them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973onirot Quote  Post ReplyReply Direct Link To This Post Posted: 18-February-2021 at 4:30AM
I hope I don't get kicked off of here for asking this but has anyone put an air ride suspension on a 73 GTS? I think my Torino would look pretty bad A$$ lowered more than factory especially with a big set of meats on the back I don't want it to set on the ground or anything like that just a little lower stance. Anyone got any ideas on this subject?
David G
1973 GTSF
