  New Posts New Posts RSS Feed - Replacing Tires due to Age/RWL Tire Choices
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Topic: Replacing Tires due to Age/RWL Tire Choices
    Posted: 03-August-2021 at 1:28PM
Thanks a bunch for that judgement of the 255/60/15's.
I plan to by four of the 15x8" Magnum wheels for one of my trucks, but the tire size and back spacing is tough to work out. The steel versions aren't in stock but those do have 4.5" BS, the aluminum  wheels by Drake are in stock, but the BS is 1/4" more, 4.75" I gather. Smaller tires could use different wheels(BS) and fit okay, the bigger tires have to be on just the right wheel size.
BadHabit351 View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 03-August-2021 at 9:41AM
Originally posted by BadHabit351 BadHabit351 wrote:
I actually lucked out. Those wheels came on a parts car I paid $200 for. They're 15x8 with 4½" back space. Those 295's sit dead center of the wheel wells. About an inch clearance on either side.
How many wheels have you tried on the front? How well do you think that 15x8 and 4.5" BS would fit the front, with 255/60/15's? That's what I think I'd like for all four, on one of mine.
My apoligies, sir...those fronts are 255/60-15 not 245/60-15. Brain fart. All 4 wheels are 15x8 with 4.5" back spacing. No rubs or interference in motion. I do have to jack the front up and let the suspension hang in order to get to the upper ball joints to grease. That's with the CVPI springs and 1/2 coil cut out.
I had 275/60-15's on the rear. I needed more meat on the rear, so I went with the 295's (1.2" wider each). That stroker puts down some torque. They are 1/4" shorter than the fronts; but I'll step down to 245's when I replace the fronts.
1973/72 Gran Torino Sport
1971 Torino GT convertilble
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 03-August-2021 at 9:20AM
AUS GTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUS GTS Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2021 at 6:56PM
good stuff!
Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2021 at 4:12PM
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUS GTS Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2021 at 2:57PM
looks like youve got some decent back space on the rear.
Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadHabit351 Quote  Post ReplyReply Direct Link To This Post Posted: 02-August-2021 at 9:05AM
245/60-15 front, 295/50-15 rear
2013 Ford Fusion
2004 Ford SuperDuty
2013 Mustang GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUS GTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-July-2021 at 12:11PM
I'm running Nankang 15", but if youre wanting to show the white lettering they would look wrong. lol
Theyve been around a long time & make decent stuff. Seem a little softer than the other stuff in this size.
No comparison shoot outs for these sort of tires that i could find.
Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2021 at 10:27AM
I have two recap tires on my "stored" Ranchero, I gave $20 each for them in about 1993. They have both gone flat many times, and one separated a little around the bottom.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2021 at 7:59PM
speaking of tires due to age... this tire of mike's did this just sitting here! it had a small split in the tread was only moved 30' and it grew to this in a year ShockedOuch
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2021 at 9:40AM
Thanks for that bulletin Rock.  My new tires have slightly browned just of a few letters just from sitting in the garage.  I was able to clean them up but now I know why they do this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 04-July-2021 at 3:14AM
I don't dress my tires, but I did that for years in a detailing job.
Try Brown Royal for a serious wheel and tire cleaner. I have a gallon of that which I needed for some used forged wheels I bought many years ago. That stuff will hurt wheels if you spray it on in full sunshine and let it dry. But it is very good to clean with, if you are careful to use it properly. I would try to only use it on a cloudy day, and keep the wheels wet constantly. I had to scrub a lot to remove old build up, and it did that, but the process also revealed or added some corrosion in places. I have liked the Brown Royal for general wheel/tire cleaning during normal car washing.
I use Purple Power for most general tire and lower side cleaning, gently on the front bumper too on occasion. I dilute that to about 20%, more than that does more damage to paint etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M. Quote  Post ReplyReply Direct Link To This Post Posted: 04-July-2021 at 2:40AM
Here is what I noticed over 50 years of raised white letter tires.
1. All turned brown over time, regardless of the manufacturer.
2. Everyone has their own methods to clean them
3. Tire shine attracts brake dust and road grime QUICKLY!
4. My aluminum wheels need weekly attention. At that time Simple Green is used on my white letters. They stay white.
  This car has Cooper Cobra tires all around.  Prior to that , the last  2 cars all ran BF Goodrich.
 So, what I've seen over the years,  disc brake dust will be noticed quickly. Tire shine  turns everything brown (I don't use it). Everyone has their own cleaning methods and personal choices for tires..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-July-2021 at 11:59AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2021 at 9:20AM
they really catch your eye going down the road, internet search doesn't come up with any distributors offering them for sale though?
another article on them popped up on another page,
"It is definitely a product aimed towards the upper crust of the auto world, though, with full sets ranging from $1,600 to $4,800 depending on your Aston Martin, Porsche, or otherwise. These colored P Zeros are unfortunately only available for 19-inch wheels and larger as well. Their tagline is “Exclusivity Changes Color” after all."
so scratch that i guess, but this is pretty interesting, https://www.tirestickers.com/consumer/
GRAN TORINO SPORT / POWER BY FORD raised whites?
GOOD ENOUGH .... MAY POP  ....
GET OFF MY LAWN!
Edited by Rockatansky - 01-May-2021 at 9:59AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2021 at 6:07AM
I have never seen those before, but they look pretty cool!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 30-April-2021 at 3:57PM
the other day i saw a new Vette  on my way home from work,
the red accent sidewalls caught my eye for sure Thumbs Up
i think they might've been these?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 27-April-2021 at 12:23PM
No Pep Boys up here.   I found a new local tire shop that specializes in custom wheels and tires.  He can get me the BFG's cheaper than anyone else in town, and  cheaper than most online vendors.  So I will probably just go with him.
The Coopers are growing on me, so I looked up the specs to compare to the BFGs.  One thing I noticed was that the BFG's are slightly taller but are a fair bit wider in the tread footprint.  In fact the 245/60-15 BFGs have a wider footprint than the Cooper 255/60-15s.  The Coopers have a higher speed rating though, rated at "T" vs "S" for the BFG.
Tread Width Diameter Weight
BFG 245/60-15 8.3" 26.6" 30 LBS
Cooper 245/60-15 7.2" 26.5" 26 LBS
BFG 255/60-15 8.5" 27.1" 31 LBS
Cooper 255/60-15 7.9" 27.0" 28 LBS
Edited by 72FordGTS - 27-April-2021 at 3:26PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 26-April-2021 at 1:32PM
Do you have Pep Boys in Canada?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 26-April-2021 at 1:20PM
Thanks for all the links, but mail ordering isn't a good option.  None of the local tire shops will mount mail ordered tires.  Plus I can get them cheaper purchasing locally.
I like Rock's idea of the Firestones that look like bias-ply tires but are actually radials.  Those tires look so much better than any modern tire.  Too bad they are so expensive and that they also only come in smaller sizes.  I also wonder how they are for handling and traction?  BFGs are just okay, but not like a modern performance tire.  But the BFGs are way better than the old Polyglas tires.
Calling around today, I am pretty much limited to BFGs and Coopers.  The Coopers are more expensive locally because no one is a Cooper dealer so there is extra mark-up.  I got a good price on BFGs so will probably just go with them again...
pete rad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 26-April-2021 at 6:27AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 26-April-2021 at 4:23AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote pete rad Quote  Post ReplyReply Direct Link To This Post Posted: 26-April-2021 at 4:18AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2021 at 3:42PM
Retro Bias Look Radials
https://www.cokertire.com/tires.html?sidewall_style=4651&tire_build=1621&tire_rim_diameter=1714&tire_type_multi=460
looks like the FR60-15 compares to a 235/60-15, it's a GR60-15 that compares to a 245/60-15
and of course they're not listed
https://www.tirerack.com/tires/tiretech/45_conversionchart.jsp
Edited by Rockatansky - 25-April-2021 at 3:56PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2021 at 10:58AM
I am not interested in running blackwalls.  I like the 70s RWL look, just like when the car was new.  My favorite look was the original Goodyear Polyglas tires, but I am not buying repro Bias-plys. I also like to run a bigger tire that stock tire.  The BFGs looks good as RWL, so did the old Goodyear Eagles (long out of production).  I just find the Coopers have too much writing and it is too big.  If they dropped the Cobra and just said cooper, I think they'd look a lot better.
I am running 245/60-15s all the way around and will stick with that size.  The redlines are pretty cool too, but it doesn't look like they list my size.  We need someone to photoshop the redlines onto a 72 GTS
so I could see how they look.
These were the original tires :
Those look very good with minimal lettering.
paj1965 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paj1965 Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2021 at 10:47AM
Have you considered the Coker Tires Firestone wide oval radials?
My Toy List:
1972.5 Gran Torino Sport
2001 Mustang Cobra Vert
2001 Lightning
2013 Jeep Wrangler
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2021 at 5:43AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2021 at 5:24AM
i gotta wonder what if anything the affected Raised Brown Letter tire owners tried to get them white?
Westley's changing their formula (changed ownership) sure hasn't helped the whitewall community,
that Censored used to be the Go To but it don't work worth a Censored any more.
the Old Man used to keep a brass brush in the detail bucket for the WW's & RWLs
what size are you looking at, what do you think of Silvertown Redlines?
(it's a T/A Radial)
https://www.summitracing.com/search/part-type/tires/product-line/coker-bfgoodrich-silvertown-radial-tires/sidewall-style/redline?ppckw=dsa-pl-tires&gclid=Cj0KCQjwppSEBhCGARIsANIs4p6JBo0xzB2nKaVg4qRpSpFEha4LdiW1cJuliuMq1cUPV5gY-h8vyR0aAv4_EALw_wcB&N=sidewall-style%3aredline
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2021 at 4:51AM
I also noticed those two tires coming up as the only choices for a couple of sizes I was interested in. The Cooper's were better for me, pricing and reviews, plus I have like the several sets of Cooper tires I've used recently.
How would you like the tires with the white letters inside? I would prefer the black walls out for my use, so is that an option for you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2021 at 4:32AM
Thanks guys, the more I read, the more it seems that 10 years is the maximum for tires to be on the safe side.  My tires have an easy life, staying in a climate controlled garage and have minimal UV exposure, but in the end tires are cheap insurance.
I am reading problems about BFG Radial T/As having browning letter problems.  Anyone have this issue?  I am probably just going to stick with Radial T/As as they are easily available locally and I have had okay luck with them over the years.  I could probably special order the Cooper Cobras (they aren't stocked by any of the local tire shops), but to be honest, I am really turned off by the look of the RWL on them.  That is just my personal preference, so I don't mean any offence to those who like the Coopers.
This page was generated in 0.172 seconds.
