  New Posts New Posts RSS Feed - 4 wheel Disc Brakes
4 wheel Disc Brakes
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Topic: 4 wheel Disc Brakes
    Posted: 13-July-2021 at 12:19PM
 i think your issue with the hose is the calipers are different!!! note the hose where it mounts, and the 2 dimples cast into the back of the caliper....mine arent like that!  mine are new for a 79 lincoln mark V as the hoses have the curved metal part too (i have aftermarket braided hoses) but the OEM hoses were the same shape!
Dmarc28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmarc28 Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2021 at 9:26AM
Ok, so this morning tightened everything up. Tried what everyone had suggested, about the caliper bracket being in the wrong sides. Flipped them but still needed the spacers. Not sure why, but I do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2021 at 4:34AM
Calipers are in the right place/orientation.
Your caliper mounting brackets are upside down.
The "Key" and retainer bolt are on top. They should be on the bottom.
I don't know if you can just flip them or you also have to swap them side to side.
Your caliper brackets attach to the bearing retainers. They may have to be swapped side to side as well.
I do know that they are not right and unsafe with those spacers. Spacers should not be needed. Something is not right.
Please be careful...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmarc28 Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2021 at 8:19AM
Hey everybody, here's an update.
You all bring up very very good points.
When I got the rearend, yes, it was all in peices and missmatched at that. So I had to do alit if digging and research to find any parts that I was going to still need to make it happen.
With that being said. I too am not fond of the spacers. I am merely using them as place holders until I can either find a solid spacer or now that I have the measurements get some made. Eventually it will be changed.
As far as the caliper brackets go I tried a few different combos before I bolted everything together. I even took a look back at the pictures that Californiajohnny shared.
I tried to match my caliper position to the picture. The hose that feeds the caliper with fluid would hit the shock mount bracket not allowing the caliper to sit correctly, thus the spacers. Eventually I plan on Getting custom retainer/caliper bracket made, but that's a long way off.
Right I want to jus get it in the car. So that's what I'll be doing today getting the old rearend removed and then new one put in.
pictures to come.
And at 8:50pm we are in. Tomorrow tighten it up and figure out the e-brake n some other stuff.
Edited by Dmarc28 - 12-July-2021 at 4:48PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 11-July-2021 at 10:48PM
yes that's what i'm thinking ... they are on the wrong sides?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2021 at 11:43AM
Dmark28 seems to be using Mark IV or V parts. That's what Johnny has. Unfortunately, Dmark28 got them as a pile of parts. So, the issue is sorting the parts and assembling them in the correct order without seeing them assembled properly.
From pictures, his calipers are hitting the shock and upper control arm brackets and needed to be shimmed. They appear to be out of place, not concentric with the rotor.
Johnny's pictures show the caliper retainer (and bolt for it) the the bottom of the caliper.
Dmark28's are on top. That tells me the caliper mount bracket is upside down. Caliper mount bracket bolts to the bearing/axle retainer. I don't know if they are symmetrical, or different from side to side.
Either way, this mislocates the caliper.
In his original pic, the calipers are forward of the axle instead of behind it. This appears to be corrected, but the shims are a new symptom.
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2021 at 11:15AM
Ok I am confused my 90 markV11 has 10.8 rotors my 79 ltd2 has 11 3/4 according to auto zone. 89 crown vic has 11.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2021 at 7:35AM
look at the radius of the caliper in relation to the inside of the wheel, flip it and it looks like it would match better
and YES measure that washer stack and cut some spacers out of some good hard material,
you might even find something usable in the drawers at the hardware store Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2021 at 4:23AM
The caliper mounting brackets are on the wrong sides, I don't know if the bearing retainers are on the wrong side as well, can't tell from the pictures, and don't know if they are the same for both sides.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2021 at 3:51AM
I sure don’t like that stack of washers..... I don’t care how tight you bolt something— those could shift
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2021 at 2:43AM
The improved pic, with arrows...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2021 at 2:21AM
He moved them to the rear in the later shimmed pictures.
Something's not right though.
Any chance the caliper brackets are on the wrong sides? driver/passenger? That would turn them upside down and affect mounting/clearance.
Your caliper retainers are up on top. Johnny's are at the bottom.
Edited by Big Bird - 10-July-2021 at 2:38AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2021 at 10:14PM
here's a pic of the passenger side...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2021 at 10:10PM
 i looked at your pic above and the calipers were in the front... they go in the rear like in my pic that's the driver side  but i'm thinking you have the mounts on the wrong sides? the ancor bolt should be at the bottom... maybe that's why you had to use the washers???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmarc28 Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2021 at 10:44AM
Yes sir, my buddy that's building my engine gave it to me all in pieces.
Buuuuut they were all miss matched pieces. But I was able to make it work.
So I'm going to get everything prepped on my ranchero this weekend, so I can get ready to swap.
Only thing I'm sketchy about is the parking brake stuff. But I'm sure it will be ok.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2021 at 8:46AM
did you use the lincoln diff? it should fit fine mine did...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmarc28 Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2021 at 7:10AM
It is a number of them. I am using a grade 8 bolt, lock washers(spacers) and lock tite.
Once everything is under the car I was possibly thinking of getting a customer axle bearing/caliper bracket made to fit.
And thank you.
mkshelton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mkshelton Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2021 at 2:47AM
That is quite a few spacers. I would make sure that I was using the absolute highest rated bolt I could find. looks good though,  great job
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmarc28 Quote  Post ReplyReply Direct Link To This Post Posted: 08-July-2021 at 7:36PM
Hey everyone, finally have an update.
Finally got everything assembled.
Had to add some spacers to the caliper bracket because the caliper was hitting the shock mount. So spaced them out, bolted them on, added a wheel adapter to go from 5x5 to a 5x4.5 wheel bolt pattern.
I have some pictures.
Idk why the pictures upload all funky. They looked fine when I took.them ha. But this is way will be going in my Chero.
Edited by Dmarc28 - 08-July-2021 at 7:47PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2021 at 1:46AM
Those look great. For braking power, the OEM 70's discs may be the best choices, but I haven't checked the caliper piston size(affects power and balance). Ford did make good thick rotors back then, they made them thinner as time went on into the 90's.
I will prefer the later model brakes for ease of maintenance and finding parts. But any upgrade is a good thing IMO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmarc28 Quote  Post ReplyReply Direct Link To This Post Posted: 29-June-2021 at 4:02PM
Hi, I just saw this.
I would love the proportioning valve if it is still available.
I jus got my rear end back today. I'm going it have to rotate the calipers and brackets, but all in all it looks fugging amazing.
Looks like this now.
But Started out like this.
madmaxtorino View Drop Down
Zombie Killing Training Instructor
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 01-June-2021 at 2:37PM
I have an NOS proportioning valve out of the four wheel disc brake cars, still in the ford box if you need one. will bolt on where your stock one is just different internal valving.
Allan
Revelation 6:8
When there is no more room in Hell, the dead will walk the Earth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 11:41PM
todd: do you remember the distance from the center of the brake pedal pivot to the center of the HB rod attachment point on the pedal? i measured it on the astro van i removed it from but forgot nowConfused
Hey CJ,
 I moved my pivot point on my brake pedal to give me a higher pedal ratio, IIRC. Doing this also lessened the angle on the input rod. I do not remember what the exact ratio worked out to be off the top of my head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 7:28PM
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 7:25PM
here's my thread showing this... follow along on the next couple pages...
http://forum.grantorinosport.org/johns-74-sh-clone-build-thread_topic10024_page63.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 7:16PM
i info is here scroll down this link until you see scott's post listing the 6 or so 2005-----pdf files listed read threw them it will tell you all the info that's what i did on mineThumbs Up
http://forum.grantorinosport.org/1972-torino-brake-upgrade_topic413_page1.html
here's the rear of my car i did the front conversion first, the bigger front rotors gave me nearly twice the stopping powerShocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 3:59PM
There's a bunch of ways to upgrade the brakes, the OEM 70's Ford parts are the most direct with the least modifications needed. You are using some of that which you already have in hand. I'm planning my project with parts I don't have yet, but seem to be more common to find at parts stores. They will take more work to adapt for the most part, but they might be a little better in the end. I wish a lot of this information was known to the public in the 70's. It takes a lot of years for people to figure oot these details for parts swapping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmarc28 Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 3:49PM
Oh no worries. Yeah for sure, you guys completely helped out.
That's my fault, I jus wasn't sure if some of the other stuff was for me.
-DeMarco
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 3:45PM
Originally posted by Dmarc28 Dmarc28 wrote:
Are you talking to 72 Rd 351?
I'm sorry DeMarco, for cluttering up your thread. I thought you had received a very good answer to your question about MC and prop valve etc. I know that aquartlow is very familiar with various brakes, and the hydro boost systems for his Ranchero.
I think John was suggesting to you and me, or everyone, that there are bolt on rear disc brake parts from other 70's Fords, which need less extra stuff or labor. I hope your project goes smoothly, and a big block is a special deal of its own.
Post Options Post Options   Thanks (1) Thanks(1)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2021 at 2:07PM
Hey Don,
 Not sure if the question above was for me, but IIRC the Mustang MC has mounting bolts/studs that are vertical whereas the T-bird and most Ford MC's have horizontal mounting points. That said, if you get a 99-04 Mustang HB then just use the Mustang MC of course. Not sure if this applicable, but as far as the mounting bolt pattern of the Mustang HB unit itself, I am not sure if it matches anything else. When I did my HB install, I used an Astro-van HB unit which utilizes an easily removable mounting plate which allowed me to fabricate a mounting plate to match my Ranchero's original brake booster mounting stud/firewall mounting hole configuration. Hope this is helpful
That helps a lot, thanks. I prefer to use parts that are easier to get, and to install. So I'm not too picky, if the 99-04 MC doesn't adapt easily to the old Fords, I'll look at the Astro van for that hydro-boost MC.
I have a 95 CV still, and the rear rotors until 2003 were solid, and the 03+ is a vented 12" size, similar to the Cobra except with different piston sizes. I know the parking brake cable is odd(perpendicular going in), so it will require welding a tab onto the rear to hold the cable.
 I would say using the Mustang set-up as a whole would probably work well, now if trying to use a Mustang HB unit(hydraulic portion) and not use the vertically mounted Mustang MC then that would probably give you issues(trying to find another MC that will physically mount and work). I used the Astro van HB unit(hydraulic portion that mounts to firewall), but my MC is sourced from an '80 Corvette. I know sounds difficult/involved, but the Astro-van HB unit uses a shallow bore MC, which the Corvette MC has. The 'Vette MC also is a 4 wheel disc 1 1/8" bore MC and it has fender exit ports(I wanted this to get brake lines/hoses away from header heat). Yes, the '98-'02 rear rotors are solid(I did buy drilled and slotted for my application) and I also had to fab up E-brake cable routing and connection to Ranchero E-brake cable. As far as the Astro-van HB unit goes, it is very easily adaptable to just about any firewall, just need to pay attention to the HB unit's input rod in relation to the vehicle's brake pedal attachment point( I had to cut and weld the rod to work with my application). I initially cut the rod to be able to totally disassemble and re-seal the HB unit, once re-sealed I welded and gusseted the rod to add strength. I did many two feet on the brake pedal stops to ensure that there would be no issues, been installed since '10 or '11 and it's been all good.
