  New Posts New Posts RSS Feed - Rear Oil Seal Replacement - 73 351W
Greg73Oregon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg73Oregon Quote  Post ReplyReply Direct Link To This Post Topic: Rear Oil Seal Replacement - 73 351W
    Posted: 13-November-2021 at 12:09PM
FYI:  Only had to disconnect the transmission cooler lines at the radiator, and the fuel line from the pump to the carb.
Then, unbolt the engine mounts on the frame side, jack-up the engine enough to place a piece of 2x4 (maybe 6" or so long), under the engine mounts.
Although either style of pan gasket (one piece or three piece), save yourself a LOT of time, and install the one piece!
GKF
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 19-July-2021 at 10:52AM
LOLMyth NOT busted. You asked about doing it without jacking up the engine...LOL
Originally posted by Greg73Oregon Greg73Oregon wrote:
With the engine in the car, can the oil pan be removed without jacking up the engine?
and you jacked it up...
Glad it worked for ya!Thumbs Up
piper62j View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper62j Quote  Post ReplyReply Direct Link To This Post Posted: 19-July-2021 at 10:12AM
I had to drop the front sway bar for clearance.. Easy Peasy
Post Options Post Options   Thanks (1) Thanks(1)   Quote Greg73Oregon Quote  Post ReplyReply Direct Link To This Post Posted: 19-July-2021 at 9:27AM
Myth Buster! Thumbs Up
I jacked up one-by-one each side of the engine, to remove the frame bolts, and then continued to jack until I could fit a block of 2x4 underneath each motor mount.  I also disconnected the transmission cooling lines from the radiator, to be able to move them out of the way (Slide the pan underneath).
Unbolted the pan bolts, and removed the pan - replaced the rear seal, installed a one-piece oil pan gasket (Fel Pro).
Piece of cake - a walk in the park.
GKF
Post Options Post Options   Thanks (1) Thanks(1)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 05-July-2021 at 2:26AM
You would need to lift the engine to drop the pan. It's not got enough room to drop/move forward enough to work on the seal. The engine is too close to the crossmember.
Pulling the bolt that goes thru the mount and frame, jacking the engine up and putting blocks under the mounts to hold it all against the trans tunnel, you can weasel the pan off, but you are still trying to work up thru the steering and all that crap.
Then Scope creep kicks in:
Pull the engine, less frustration. Also allows you to clean out the oil pan/screen, realize there are timing gear nylon bits in the pan, strip the entire engine down, performance rebuild.
Detail the engine bay while it's apart. This helps you realize that the car really needs a paint job.
When that's done, it's interior time.
Oh, and all that old chrome really looks bad against the new paint...
Suddenly it's seven years years and $Censored* later.
That's what happened with my brother's Cutlass.
(* $ amount censored to keep it from his wife, who still doesn't know how much...LOL)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg73Oregon Quote  Post ReplyReply Direct Link To This Post Posted: 04-July-2021 at 5:55PM
The '73 has a two piece oil seal.  Not the one piece as in later years.  So I'm thinking that it still might be possible to replace.
GKF
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 04-July-2021 at 5:48PM
Typically no, the engine would have to go up more than is possible with the trans attached. It hits the firewall before there could be enough clearance for the oil pan. To change the rear seal, basically you have to remove either the engine or the transmission.
73 Ranchero Sport "72 front end", floor shift/console, planning EFI 7000rpm 351-4V &4R70W
73 Ranchero GT 351C-4V 3.70 gears for sale later.
92 Lincoln Mark VII SE, OBDII 347/4R70W
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg73Oregon Quote  Post ReplyReply Direct Link To This Post Posted: 04-July-2021 at 3:12PM
Examining; looks like the transmission cooler lines and maybe the front sway bar have to be removed in order to push the pan forward.
But, I'm wondering if manually cranking the engine until the rear pistons are up, that there might be enough clearance to slide the pan forward.
Any help is appreciated.
Thanks!
GKF
This page was generated in 0.096 seconds.
