Yet another seat question |
72 RS 351 ![]() Senior Member ![]() ![]() Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 1905 |
![]() ![]() ![]() ![]() ![]() Posted: 24-February-2022 at 6:55AM |
Thanks, those look like a great fit, and the bolt pattern looks workable. The pre-1990 Mark VII seats have the adjustable bolsters. They are a little more comfortable than the 1990-92 seats, which have no separate front bolster. This was from 1996 in my first LSC SE, the almost white interior(fire and ice edition it's nicknamed). ![]() |
73 Ranchero Sport "72 front end", floor shift/console, planning EFI 7000rpm 351-4V &4R70W 73 Ranchero GT 351C-4V 3.70 gears for sale later. 92 Lincoln Mark VII SE, OBDII 347/4R70W |
Eliteman76 ![]() Admin Group ![]() Joined: 20-March-2006 Location: Nebraska, USA Status: Offline Points: 4758 |
I forgot. The SVO and Mark 7 seat lowers use a different bolster. Supposed to be adjustable, m7’s are power I believe. I have never bothered to power mine up after over a decade.
Fox body and Mark 7 seats are the same.
Mark 7 seats as far as I can tell use the exact same foam and lower that the 1984 SVO mustang uses. If you look in my 17 year barn nap build blog, I have details on recovering Mark 7 seats and how they were the same as my previous 1988 Mercury Cougar XR7 seats. Main difference being power bolsters. Cougar xr7: |
Are the Fox Mustang seats about the same actual size, width? I ask because a late 80's Mark VII seat is really nice if you can find them. I have a friend with one spare pair, and plan to put those into my 92 Mark VII. I could use my old 91 seats from a prior car, similar but different.
Dave, I used Foxbody mustang seats on the GTS. Foxbody compared to factory Torino, the track width is 3" narrower compared to OEM 72-76 Torino buckets. I made simple spacer plates using 3" long plates. 2 holes drilled 1" on center with one stud welded so I could bolt to the foxbody seat, and then bolt to the OEM torino seat tracks.
Been that way for many years. As are as the pre-72, Ford liked to use similar structural items like the seat frames and adapt different tracks. If you ever looked at the 72-73 highback GTS buckets, the structure of the seat frame is remarkably similar to 70, and 71-73 high back Mustang buckets. |
hogfiddles ![]() Senior Member ![]() ![]() Joined: 19-September-2016 Location: Central NY Status: Offline Points: 1051 |
turns out my mustang seats don’t have the tracks/base assemblies on them so I STILL can’t compare. I guess I’ll take the assemblies off of my torino sweats and see how much would be involved in swapping them on a workbench
pete rad ![]() Senior Member ![]() Joined: 29-November-2014 Location: usa Status: Offline Points: 303 |
I believe that the '69 torino is 2 and a half inches wider from the drivers side door to the passenger side door, than the '69 and '70 mustang. The 69 torino is also 3 and a half inches longer from the front bumper to the rear bumper than the 69 and 70 mustang.
So the mustang seat bases might be too short in width to mount onto the torino seat frames. And the torino seat bases are probably longer in length from front to back compared to the mustang seats. But you can make or find brackets to mount the mustang seats onto the torino seat frames. I doubt they will be a direct fit.
Edited by pete rad - 28-November-2021 at 11:02AM |
Big Bird ![]() Senior Member ![]() ![]() Joined: 25-August-2013 Location: New York Status: Offline Points: 4145 |
Actually the Mustang is based on the Fairlane, but the Fairlane bench seat cars don't always have the bucket seat supports in the floor pan. Also applies to 66-69 Falcon.
Platform was modified for Mustang, so some things are different.
alright…….does anyone have a ‘69 Torino bucket seat already out of the car so they could take some careful measurements for all 4 holes? I have a set of ‘69/‘70 bucket seats, so I can measure here……
That's a great possibility Dave. The seat track is the special part, get that and see if the bolt pattern will accept most OEM seats. You could put tons of various models on those seat tracks if they do match.
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14120 |
hmm, i think you're onto something dave?!!
Ok, here’s a question…….if i’m reading things right, and I think the ‘69 Torino is based on a ‘69 mustang platform———————will the 69/70 mustang bucket seats bolt into the ‘69 Torino?
Dfox
