1973: Rear Tail Pipe Bracket - Dual Exhaus |
lynchster ![]() Senior Member ![]() ![]() Joined: 07-January-2006 Location: Pennsylvania Status: Offline Points: 2033 |
![]() ![]() ![]() ![]() ![]() Posted: 25-June-2022 at 6:06AM |
They are the same on my car
72 Gran Torino Sport 08 Taurus (Maytag) 03 Dakota (Rusty) |
Greg73Oregon ![]() Member ![]() Joined: 23-February-2021 Location: Roseville, CA Status: Offline Points: 114 |
I don't have the part number, but I have pictures of my passenger side rear bracket.
This style is what I am looking for. I drilled out the rivets, took apart, soaked in white vinegar for a few days, and then took a wire brush to it. Then I spray painted it. For the rubber, I got some scrap conveyor belt rubber. I used a stainless steel "button-head" bolt and nut to mount at the rivet holes. I need another one, as I am installing dual exhaust. |
GKF
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 4961 |
Do you have pics? Or as Ford part number I can check? I believe they should be basically the same.
I'm adding dual exhaust to my 1973 Torino.
I picked up the driver's side bracket from an unknown year. But it looks MUCH different than the passenger side. Are the brackets from a factory dual exhaust the same, other than opposite construction (since they are facing opposite direction)? Or are they way different looking? Thanks.
GKF
