460 car fan shroud |
76GranBroughamTorino
Brand New Member Joined: 13-December-2023 Location: Alaska Status: Offline Points: 1 |
Posted: 31-December-2023 at 7:16AM |
I reused my 400’s shroud when I swapped in my 429 20 years ago. Never had any heating issues
76 Torino Gran Brougham
429/C6 |
yeah mid 70's lincoln ... most had 460's and should be the same?
Mark IV, V should work, Same basic chassis, 2 door cars on the 4-door wheelbase.
72 RS 351
Senior Member Joined: 04-September-2014 Location: Knoxville TN Status: Offline Points: 2767 |
How close would a late Crown Vic fan shroud be to fitting the 70's Fords? Those from the CV have an electric fan inside them along with a mechanical(thermostatic) fan. If they would fit, those might be a stock looking alternative.
CJJ
Member Joined: 10-January-2021 Location: Canada Status: Offline Points: 114 |
Good to know thank you. Mid size Lincoln be the same as for Torino you think?
aquartlow
A 429-460 is so much closer to the radiator, if a small block or M-series shroud is used, the fan blades would be too far inside the shroud to be 100% effective. The engine side of the fan shroud edge "should" be on the same plane as the center of the fan blades(or at most just at the rear edge of fan blades) once installed to be most effective.
CJJ
I think, but not sure they do? Suspension parts yes, can’t see why a shroud would be different?
The 429/460 used a different shroud. I thought it was repoped for a while?? Not sure off the top of my head if the Lincoln Mark V (or even Mark IV) shroud would work, since they were mostly Big Block.
CJJ
Thanks Johnny. The search continues…..
i think they are all the same except the 460?...
CJJ
That I’d sure like to know?
351M, 400 and 429 may be the same shroud
CJJ
Hey I’m looking for a shroud. My Torino is 76. Thanks
