  New Posts New Posts RSS Feed - 1975 Torino steering knuckle foam seal
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Topic: 1975 Torino steering knuckle foam seal
    Posted: 13-January-2023 at 11:24PM
RTV is cheap and available
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2023 at 10:16AM
Those are basically factory only and made to reduce debris from getting to the seals and bearings. So most people leave what's there in place. You could try to add something if it could survive the heat, but it's not critical.
pyntre View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pyntre Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2023 at 8:33AM
Disassembling the front end for a rebuild ,when I removed the dust shield from the spindle / knuckle , I noticed the remnants of a foam seal . It is attached / glued to the face of the spindle , around the inner grease seal flange .  Is that a part that’s available anywhere anymore ? I imagine it’s there to prevent grit/dirt from getting into the seal area . There wasn’t much left of them , but should probably go back together with something that resembles it . Any suggestions??
This page was generated in 0.064 seconds.
