  New Posts New Posts RSS Feed - Frame swap
Frame swap
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Topic: Frame swap
    Posted: 11-May-2023 at 2:05PM
Anders……it’s spelled “Wuss”—-LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 11-May-2023 at 2:04PM
What's funny is on the Assembly Line pictures I have the cradle for our cars grabbed the roof rail, and the rear quarter panel wheel lip.
Would love to see copies of that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2023 at 3:59PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2023 at 8:32PM
 i did mike's car the same way Wink
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2023 at 8:14PM
I was a big woos when the frame of my car needed repair. I caved and took the car to the pro’s. I was struggling with 2x4’s and straps….
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2023 at 7:59PM
 ahh!!! forgot that S hook on the cable!!!!  when i lifted mine, it went up about a foot then the front started to tiltShocked lowered it down, moved the sling ahead about 1" raised it and it tilted againShocked lowered it down, moved the sling ahead another 1" still tilted Shocked lowered it and moved the sling strapping about 6" forward! still went up about a foot and tilted!!!Angry looked under there and saw that S hook on the cableEmbarrassed lowered it back down again and moved the sling back to the original balance point removed the hook and it worked flawless then WinkLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2023 at 3:16PM
Looks plenty safe to me ……probably safer than how I did it—
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2023 at 5:10PM
I would not recommend what I did what so ever. Death wish. Ah. To be young and really dumb...
72MLC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72MLC Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2023 at 4:06PM
Thanks for the replies. Like I said, I tend to overthink. If I can ever find another front end, may even try and save the donor one day.  Rotted roof due to the vinyl top but otherwise a running 35k original mile formal roof. The sportsroof is the one I'm bringing back to life.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2023 at 6:48AM
Ditto, the frames are very stout and if it's just the front snout the bumper bolts to, that's not hard to fix. The only tricky thing is making sure that mounting surface is very close to the original. The bumper adjustment is all in the shims there, and movement possible up/down/left/right due to the hole slots.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-January-2023 at 6:35PM
 a few guys have lifted the body with 2 cherry pickers... ive done a couple with my HF overhead winch... but if its just the front frame horn id cut and graft a straight section on...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72MLC Quote  Post ReplyReply Direct Link To This Post Posted: 21-January-2023 at 3:46PM
Hey gang! I have gone back and forth for a while now on if I wanted to frame swap with my donor car since it's immaculate. Mine isn't bad other than a front bumper mount bent but the other looks nicer. While not necessary (unless it being a power brake car versus mine not) what is the easiest way for me with a 2 car garage? Or is it better to attempt to find a place that may have better equipment to do so. Searched as usual, looked at youtubes etc and it looks like out of my skill set or I'm over thinking it (I am notorious at that) Thanks as always!
