  New Posts New Posts RSS Feed - Instrument cluster lens?
Anderslober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Topic: Instrument cluster lens?
    Posted: 28-February-2023 at 6:53AM
Hi forum. What do you fellas do for new lenses in instrument cluster on 70 Cylone?
Have any of you tried to polish the lenses? If so, what did you use? Thanks.
Edited by Anderslober - 28-February-2023 at 9:22AM
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 28-February-2023 at 9:57AM
Check "How to" section, Instrument cluster screen Refurb, discussion there on what people have used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anderslober Quote  Post ReplyReply Direct Link To This Post Posted: 28-February-2023 at 11:06AM
Thanks. I will try some PlastX or acrylic polish……hopefully does it. The lenses are a bit yellowed too….
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 28-February-2023 at 11:45AM
Almost all plastic used on instrument clusters can be polished easily with typical mild car polishes. Start with a mild polish, avoid anything that you can feel the grit in, such as most compounding products.
I have plastic cased comic book containers, the plastic is fairly tough, but I have been able to remove any scratches from them, light or deep. A tough plastic can take a real compound, but only apply it by hand. Use a soft cloth like a face cloth, terry cloth etc. it works great on the instrument cluster covers.
Compton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 28-February-2023 at 12:25PM
Autosol makes a plastic polish that works well…I’ve found that using their metal/chrome polish first then the plastic polish gives the best results
This page was generated in 0.171 seconds.
