Gran Torino Trunk Flipper Spring repair? |
hogfiddles ![]() Senior Member ![]() ![]() Joined: 19-September-2016 Location: Central NY Status: Offline Points: 1381 |
![]() ![]() ![]() ![]() ![]() Posted: 22-April-2023 at 11:06AM |
I’d have to look. The flipper and the bass are very close from the XR seven to the Torino… But there are slight differences in the casting, but as long as those don’t bother you… They can work. The inside of the disc is a different contour, so I’m not sure exactly how cleanly the Torino emblem will fit – I have some of each style. And I have a junk Torino one I will see how well it fits.
I’ll give you a call, also…
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5443 |
Very nice Dave! Do you have anymore red Torino emblems? I have an XR7 flipper that I wouldn't mind converting to a Torino flipper (identical other than the emblem).
I just finished a couple more sets— :) ![]() Dfox
spriegel ![]() Senior Member ![]() Joined: 28-September-2021 Location: Fairview, PA Status: Offline Points: 462 |
John - good advice! That was my concern - it seems like someone would do that accidentally and with these being 50 year parts, break it. -Chris
Fairview, PA '1973 Ford Gran Torino |
handsofstone ![]() Senior Member ![]() Joined: 13-April-2018 Location: Northeast Status: Offline Points: 3827 |
Never let the flipper snap back. It may not break the first time but it is a gamble on how many times you can do it without breaking something.
I had maybe $175 into mine. I always liked the look of the red emblems.
![]() Dfox
Dave, Wow, these look great! Thanks Troy for the photos, I see what they did - I was wondering how it would create the leverage to spring back, but see how they wrapped the spring around the tab and used a bolt/screw for the top. Thanks, Chris
Just finished another (except for the black that I have to paint on yet.....)
![]() Dave Fox
Agreed!
Thise look excellent Dave. I think the biggest problem was when opening the trunk a lot of people letting it snap closed. That most likely killed many over the years.
Correct, usually one of the fingers breaks off. I have rarely seen (and have never had) a spring itself break. The bigger problem is that the metal is pot metal, which makes metal repair very difficult. I’m still trying to find a tried-and-true way to repair pot metal myself... some way that can handle some stress.
I am in the middle re-habbing some ‘72-‘73 flippers. Here’s how the current two look.... they’re getting close to finished: ![]() Dave Fox |
Yellosn ![]() Member ![]() ![]() Joined: 14-February-2020 Location: Eugene, OR Status: Offline Points: 133 |
I have one that came with my car that has been “repaired”. A little hokey, but it works. I got another one but kept this as a spare.
Troy Emerson
Eugene, Oregon 1972 GTS 4speed |
@Hogfiddles repairs them. Ping him via pm, or wait and will be by shortly most likely.
John, Troy, Do you have a picture of the tab? or how it is configured? Any ideas if something could be fabricated? We have a local True Value that carries a lot of springs - I was going to try to fit one, but I'm not clear what is attached to, in order to create leverage? Is that the tab that breaks? Chris
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14512 |
troy is right! that tab usually breaks
I think it’s usually the little pot metal fingers that give before the spring.
Troy Emerson
Has anyone repaired a '73 Gran Torino trunk flipper w/ emblem? My current flipper works w/ spring, but I bought a spare as it seems like something that would break over time. The spare I bought looks good, but doesn't have a working spring. If you have repaired one, could you post a "how-to" w/ photos? Thanks! Chris
