  New Posts New Posts RSS Feed - Column Shifter Support Bracket?
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Topic: Column Shifter Support Bracket?
    Posted: 28-March-2023 at 3:59PM
If it is there's a bushing missing from the looks of it.
dan0R30 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dan0R30 Quote  Post ReplyReply Direct Link To This Post Posted: 28-March-2023 at 5:12AM
I'm putting my Torino drivetrain back together and down to the last few items. Sitting next to my starter and flexplate cover was this bracket. For the life of me I could not remember where this came from! After an hour of test fitting, I think I convinced myself it's a support bracket for the column shifter. It would bolt into the bell housing if my picture is correct. If this is the case, should there be some grommet or clip where the shifter linkage penetrates the bracket? Or is this not the right application for this bracket? Confused
Dan
1970 Ford Torino hardtop - 351C 4V - FMX - 9" 3.00
