  New Posts New Posts RSS Feed - 73 Gran Sport Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Topic: 73 Gran Sport Torino
    Posted: 31-January-2024 at 6:05PM
The issue with the cluster is the speedo cable to the back of the cluster has a retaining clip.
It's easier to pull the dash pad off the top of the dash, to allow more access.
Be gentle with the cluster as due to age, they can get really brittle and fall apart on cars that saw a lot of outdoor exposure.
Chasing electrical can be a headache but sometimes...pulling the entire dash out and inspecting things when you suffer electrical issues can prevent potential fires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2024 at 1:46AM
I had an issue like that in 1989 with my ‘76 Gran Torino...... turned out to be a worn wire up in the steering column.
Bubba_Clide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bubba_Clide Quote  Post ReplyReply Direct Link To This Post Posted: 21-January-2024 at 12:39PM
Unplug the 2 wire plug from your radio and then try. I had the same problem and came to find out the ground for my aftermarket radio was plugged into the power wire thats for the lights inside the factory radio and thats what was blowing my fuse
carguy47 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carguy47 Quote  Post ReplyReply Direct Link To This Post Posted: 19-October-2023 at 7:13AM
Great looking car!
You have to build em to drive em!
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2023 at 6:40AM
I had same issue after burning up light switch on way to Ky 2 mo ago I got around to fixing it Find the blue w red stripe or gray w red stripe splice at lite switch install 10 amp fuse and find same wire at dash harness,side not the dash harness has two one for cluster other for heater radio etc (I
missed second one)but now have dash lights green leds.It only took me 9yrs good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2023 at 3:48PM
i've seen the dash light wire to the radio mistaken for the ground,
and it took out the dash lights .... Ermm
Roach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2023 at 8:04AM
Thanks California Johnny, I will check out the bulbs and track the light blue wire. I took off the face covering and removed the 4 screws holding on the cluster. Evidently that does not allow me to bring the dash cluster forward enough to check anything.  Only could move it forward about an inch or so. Do I have to remove the entire dash to get to the back of the cluster?
Also, wanted to check the light switch out but I thought that you just pull hard enough on the knob to get it off, but it seems awful tight. Don't want to break anything in the process.
Thanks again
Rick
Rick Cochran
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 29-September-2023 at 10:09PM
 if it blew the fuse immediately i say theres a short somewhere dash lights are a light blue with a red stripe wire... look for any rubbed bare spots also check the small metal lights that light the wiper switch and the heater control areas maybe a bulb is missing and the wire end pushed inwards with no bulb and shorted out???
missing linc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote missing linc Quote  Post ReplyReply Direct Link To This Post Posted: 29-September-2023 at 4:57PM
Very nice car, love the green!
Cars are meant to be driven, not hidden away collecting dust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Posted: 29-September-2023 at 7:27AM
Thanks for all the great comments. Still trying to figure out the dash lights. Found the fuse and it was blown. replaced and as soon as I turned on the lights it blew the fuse again. I guess it is either a bare wire or does anyone think it could be the light switch? If anyone has any suggestions, please let me know.
Drives great and got everything working except under hood light and dash lights. Just can't drive after dark.
Thanks again, Rick
Rick Cochran
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2023 at 1:22PM
Very nice! The colour combo is sharp.
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2023 at 1:09PM
Beautiful car!
spriegel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spriegel Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2023 at 11:43AM
Looks great!  Now it's time to have fun driving it!
Fairview, PA
'1973 Ford Gran Torino
Wayner315 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayner315 Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2023 at 3:02AM
Dang green is nice. I have a green interior that's going to stay green, so perhaps Green paint in my future. Very nice car.
72 Gran Torino formal roof Brougham
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2023 at 2:30AM
Very nice! One of the colors you don't see too often but definitely is striking in GTS body style.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2023 at 2:25AM
Finally about to finish up Torino. Got new trunk mat and floor mats ordered. Having problems with dash lights but will keep trying to figure it out.
Will get more pics later.
Rick Cochran
