  New Posts New Posts RSS Feed - 351 w swap
351 w swap
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: 351 w swap
    Posted: 08-December-2023 at 4:46AM
will a 68 351 w work in a 79 or are there issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2023 at 6:11AM
The 351W should be a simple swap given the external dimensions all match. The front dress and carb/intake will vary for the given models, but either could be used as needed. I'd still be interested in a late model front dress if you prefer a serpentine belt system, and can adapt the AC lines for a later compressor. The possibilities are countless, anything you'd like is possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2023 at 8:24AM
someone once said deck height was different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2023 at 9:33AM
The earliest 351W block is supposed to be a hair shorter I think. The normal spec is 9.50" block deck height, note the Cleveland block is 9.2", shorter by .30" which makes a bigger difference(intakes etc).
That could only affect the compression very slightly, and the fitment of an intake manifold. In any case you can still mix the parts if you take normal assembly steps, checking deck height and test fitting the intake before tightening bolts.
It's like the first 289 blocks that had just five bell housing bolts, true but they still are usable.
Edited by 72 RS 351 - 08-December-2023 at 1:36PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2023 at 10:21AM
nominal deck heights are 9.48" and 9.5", makes no difference unless you're doing internal engine work like replacing pistons or doing a stroker. my 1968 302 had a 3 bolt harmonic balancer vs the common later (1969+?)4 bolt hub. i'm not positive but i suspect the balancers are interchangeable? IIRC the 68's also used a unique (rare and expensive / valuable) cast alloy front accessory mounting bracket but i forget ATM if it was for the alternator od PS pump. my 68 302 also had a right side lower radiator hose on the water pump, which again should be able to be updated to the left side hose water pump. so the jist of it all is that the 1968 front accessory package including the balancer and water pump will need to be updated to the later style package
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 08-December-2023 at 1:38PM
Well said Rock, much better than my guess at the old dimensions. The balancers should swap, but having different bolt patterns, and the varying accessory brackets, you want to keep the ones from the car it goes into. Unless you like swapping other things for upgrades etc.
This page was generated in 0.098 seconds.
