  New Posts New Posts RSS Feed - New member from Australia
1coolbanana View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 1coolbanana Quote  Post ReplyReply Direct Link To This Post Topic: New member from Australia
    Posted: 21-January-2024 at 9:12PM
Hi all
First post, new member from Australia.
Have a 70 Torino GT, 351 Cleveland, 9 inch rear and 5 speed manual T5
Looking forward to learning lots from you guys.
Smile
Wayner315 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayner315 Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2024 at 3:15AM
Welcome I believe there are others on here from Aus.
72 Gran Torino formal roof Brougham
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 22-January-2024 at 3:27PM
Welcome Marc!  Very nice Torino you have there. I have upgraded you to a new member so you have full forum privileges.  Feel free to share more pics and tell us more about you Torino.  I bet is must really turn heads down under.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 23-January-2024 at 1:51AM
Welcome, and that's a very nice car.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 24-January-2024 at 4:56PM
Welcome aboard. Beautiful ride. What was the original color?
spriegel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spriegel Quote  Post ReplyReply Direct Link To This Post Posted: 26-January-2024 at 10:32AM
Welcome to the forum!  That's a great color!
Fairview, PA
'1973 Ford Gran Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1coolbanana Quote  Post ReplyReply Direct Link To This Post Posted: 26-January-2024 at 10:07PM
Thanks for all the welcomes.
Shes a work in progress, was in a pretty poor state when I got it but slowly getting there, bit by bit.
Originally white, now Crystal Turquoise, a local Aussie Valiant colour.
Engine just finished and running great with a Tremec 5 speed manual
dan0R30 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dan0R30 Quote  Post ReplyReply Direct Link To This Post Posted: 27-January-2024 at 2:16AM
Beautiful!
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-January-2024 at 4:03AM
Very nice. Any specs on the Cleveland build?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1coolbanana Quote  Post ReplyReply Direct Link To This Post Posted: 28-January-2024 at 9:11PM
Hi, thanks.
Nothing super exciting. Just a mild street cruiser.
85 351C short block reconditioned (last of the Australian "black motors").
302 2V closed chamber heads giving a touch over 10:1
260/272 Cam 218/224 @ 0.50"
Hydraulic flat tappet
Air gap manifold with 1/2" open spacer and Eddy 600 Performer.
Ignition setup, 25 degrees mechanical, 10 degrees initial timing, mechanical starts at 950 and all in by 3200. Will probably bring that down to 2800 later. Standard timed vacuum of 15 degrees. Running Bosch module with variable dwell.
Likely go up a bit in the carb when I do a decent exhaust but its what I had lying around.
Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 31-January-2024 at 5:55PM
Welcome to the site. Nicely done ride.
And nothing better than a 351C with a 5 speed!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 31-January-2024 at 6:23PM
  welcome!
