  New Posts New Posts RSS Feed - 460 EFI, E4OD
460 EFI, E4OD
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Topic: 460 EFI, E4OD
    Posted: 13-April-2024 at 2:50AM
I'm going to check out a 460 with E4OD out of a camper tomorrow. Has anyone dropped this combo in their car? I have a 76 Gran Torino. I know the trans is basically a longer C6 so I'll need a driveshaft. I'm guessing crossmember as well. I'll try to find original motor mounts. My concern is that this beast won't fit under the hood with the stock EFI. Does anyone know for sure? I really want to keep everything as is. It's all still on the chassis and runs. I can transfer everything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2024 at 3:25AM
I am not sure on the 460 EFI engine, but big block mounts are hard to find for a Torino.  You can source them from any other midsized 1972-79 Ford, or also the Mark IV/V Lincoln and 1972-76 T-bird.  Crites makes some aftermarket ones (or did) but they require the use of their headers as they are different than OEM.  You'd need to get the measurement on the height of the engine vs a 460 with a carb.  On the other hand, you could grab the 460, swap intake, carb and distributor.  That's the routed I'd go, much easier.
For the E4OD, it's a very large transmission.  I don't think it will fit without major surgery to the transmission tunnel. I don't know of anyone who's done it.  It'd be easier to find a C6 and use that with the 460.
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2024 at 10:36AM
Ahh so when I read that the E4OD is basically a C6 with overdrive, I assumed it was the same size with a longer tail. My bad.
I took some measurements and I seriously doubt that EFI manifold fits under the hood. I'll look for a carbed  one if I go that route.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2024 at 12:30PM
BTW, 460 EFI heads use a different exhaust port "arrangement", 70's headers will not fit the heads and definitely won't fit your Torino. An E4OD has a larger bellhousing as compared to a C6, don't forget about the aftermarket(read $$$) trans controller you'll need for the E4OD. Hope this helps
Dino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dino Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2024 at 12:52PM
I would get whatever electronics needed from the donor. It's basically a running chassis. But I'm not up for doing major surgery. I'll just look for a 351 roller block and build something fun. I already bought a 4R70W from a Mustang a while back. I do need a controller for that one.
Dmarc28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmarc28 Quote  Post ReplyReply Direct Link To This Post Posted: 11-October-2025 at 7:18PM
Hey everyone. Jus like you guys I've been thinking bout EFI.
Haven't decided if I want to go TBI, direct port fuel injection kit or have my intake modified for direct port injection.
Found this at McGee racing.
Some specs of the engine, Kaase aluminum P-51 head, Edelbrock Victor Jr. Intake, Isky Hydraulic Roller cam 262/270 @ .50, .644 lift.
Recently got it chasis dynoed out in Jurupa Valley, at Westtwch performance group
Any advise and help would be greatly appreciated, thanks in advance.
-DeMarco
This page was generated in 0.090 seconds.
