  New Posts New Posts RSS Feed - rear-end gears
rear-end gears
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: rear-end gears
    Posted: 14-May-2024 at 12:42AM
Ok looking for new set up for 8in I want 3.55 or 3.75 online people are posting 4.56 and higher ring and pinion. One person said 4.56 is a 3.50 rear end I am confused.
derth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote derth Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2024 at 4:04AM
Without knowing anything about the 8 inch, I will mention that final gear ratio is a matter of tire size, transmission gearing and rear gearing. Depending on goals, you could start by finding your desired rpm at cruise speed and then working from there. Depending on transmission, a 4.56 may give you a 3.5 final gearing? Sorry if this is not helpful, but it was confusing for me first time I dealt with it.
Well, of course, now that I'm thinking about it, all the transmissions that came in these cars are 1:1 in 3rd, so everything I just said is useless unless you've got something with overdrive.
Edited by derth - 14-May-2024 at 4:12AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 14-May-2024 at 5:39AM
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 15-May-2024 at 6:02AM
Are you sure your car has an 8" rear, and not a 9"?  What gears are you running now?  A lot of those late 70s cars had really steep gears, like 2.50:1.  What size rear tires do you have?  What type of driving do you do with your car?  Is your engine stock or modified? What are you hoping to achieve with new gears?
Ford 8" rear have slightly different rations than Ford 9" rears.  You could upgrade to 3:00:1, 3,40:1, 3.55:1 or 3.80:1.  I probably wouldn't go much lower gears than that for a street driver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 15-May-2024 at 12:39PM
It is for my pinto going with AOD it has 2.75 there about.Someone had a 4.56 ring and pinion locker clams that is a 3.55. Just a thought I have a 3.25 non locker but people want 4-500 to put new bearings and set it up I have the bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 16-May-2024 at 2:49PM
The 3.25:1 range is not a bad ratio for an AOD car, the OD is .70:1, typical for all over drive trannies. A 3.5 or 3.75ish is also very good depending on the vehicle weight and power level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 17-May-2024 at 8:42AM
With a little Pinto, assuming it's still a 4 cylinder, be careful not to over gear it.  With the .67 OD, a 3.25 gear will give you a 2.18:1 overall ratio.  A 3.80 gear seat gives you a 2.54 overall ratio with an AOD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 17-May-2024 at 11:21AM
Well given an AOD, it'd likely be a V8 I hope, but a V6 at the least. I know how tight the engine bay is, my best friend's nephew had a Cleveland in one in the mid 80's. I hate to think how tight it is for headers, the trans, plus the exhaust. Good luck of course.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2024 at 2:12AM
It's a 302 bought it yrs ago for 1000 because who knows wife would not ride in it to loud and 6in hood scoop . took it apart found right oil pan and got old. my question was people saying 4.56 ring and pinion is a 355 ratio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2024 at 6:36AM
what they're saying, based on their own specific combo factoring in tire size i imagine?
is that with OD they can run a 4.56 gear and it equates to the 3.55 gear w/o OD
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2024 at 12:26PM
thanks.
This page was generated in 0.118 seconds.
