  New Posts New Posts RSS Feed - Intermittent Brake issues
Cobratyler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cobratyler Quote  Post ReplyReply Direct Link To This Post Topic: Intermittent Brake issues
    Posted: 06-April-2025 at 9:26AM
Hey guys, I have a 1970 Torino cobra. While out for a drive yesterday I had what felt like brake/brakes starting to bind. My question is where should I start on diagnosing this issue? I have already jacked the car up and all the wheels were free spinning.
DJsTorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJsTorino Quote  Post ReplyReply Direct Link To This Post Posted: 07-April-2025 at 6:16AM
How old are the rubber lines? I had to replace all the rubber flex lines in my car as they had swelled up inside and were causing the brakes to drag.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cobratyler Quote  Post ReplyReply Direct Link To This Post Posted: 07-April-2025 at 10:48AM
I’m not sure I just got the car a few weeks ago. But I’d be willing to bet they’re pretty old.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 07-April-2025 at 11:10AM
fronts or rears? both? disc, drum?
loose, rusted / disconnected hardware in a drum can allow the shoes to apply pressure to the drums
Jaybee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaybee Quote  Post ReplyReply Direct Link To This Post Posted: 07-April-2025 at 2:31PM
I had a brake hose go bad a few months ago. Looked fine on the outside, but fluid leaked between the layers, causing the inside to balloon together and block the fluid flow.
Cars are meant for driving
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2025 at 9:13AM
If the e brake has been applied, look to see if the cables are stuck where they enter the backing plate. I have had similar issues over the years and that waa the problem. An easy way to tell is to see if the cables under the floor are drooping down.
Wayner315 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayner315 Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2025 at 10:29AM
To expand on the rubber line issue, my understanding is that the rubber lines will let the enormous (thousands of psi?) pressure from the brake pedal through to the caliper/shoes, but then the relatively low pressure, once the pedal is depressed can't make it's way back up the line, hence the sticking. Best of luck, hope this helps.
72 Gran Torino formal roof Brougham
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cobratyler Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2025 at 9:53AM
Hey guys I wanted to thanks for your reply’s. Sorry it’s been awhile I’m sure you guys know how life gets in the way. Anyway, I finally got a chance to look and the brake hoses are brand new. Both front wheels had resistance while trying to free spin them. The drivers side outside brake pad was significantly worn compared to the one on the inside. The passenger side did not show significant ware on the pads but still had resistance. I shot some WD40 on the sliders to see if I could get them to start moving freely. If that doesn’t work would caliper replacement be the next move?
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2025 at 10:40AM
Try a little lithium grease on the slider. A little...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2025 at 11:23AM
Rockauto shows the 1970 calipers use pins in rubber bushings?
at least disassemble, clean & reassemble.
be careful what lube you use so as not to swell up / make the rubber funky
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cobratyler Quote  Post ReplyReply Direct Link To This Post Posted: 04-May-2025 at 1:00PM
Ok I’ll disassemble and clean up and see how it goes.
