  New Posts New Posts RSS Feed - INFO: 1972 Wheel lip molding repros PRE-ORDER
 Post Reply Post Reply Page  123>
Post Options Post Options   Thanks (1) Thanks(1)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Topic: INFO: 1972 Wheel lip molding repros PRE-ORDER
    Posted: 14-June-2025 at 11:32AM
I found out yesterday that Metro Obsolete is taking sign ups for 1972 and up full wheel lip moldings. I contacted them and they said they need 50 set reservations to do it. I am probably going to sign up for 2 sets. Images below of my chat, and their post.
Basically, give them a call, get put on the list, details are in the images.
CHAT WITH PHONE NUMBER AND WHO TO CALL:
Edited by 72FordGTS - 27-June-2025 at 1:38AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2025 at 1:52AM
Wow, this is big news!!  I don't need a set, but I'd order one just to have a spare.  My only concern would be how good the repops are.  I wouldn't want to invest $450 unless they are very close to the originals.
Is that price for all 4?
Have you posted this on the FB groups too?  If you aren't on there, I can post the info.  That should help get you to the the minimum 50 orders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2025 at 8:32PM
Are the rear wheel ones identical on the station wagons to the coupes? I'd hate to spend $450 and only be able to use 2/4.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2025 at 2:41AM
I have been told that the rear wheel well openings are the same for all Gran Torino models. I bought the wide molding trim from an eBay seller who also confirmed they were the same. So I hope so, I never found any different part numbers for the 2dr versus the Ranchero etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2025 at 10:45AM
I have been told previously that 72 fronts are different from 73 up fronts (front of lip is longer on 72), and 74 up are different as well..but I have not done the appropriate research to state this as fact.
Right now, i am in the "close" and "functional" search and this should work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2025 at 2:06AM
Yes, the 1972 front moldings are unique and unobtainum, which is why I wouldn't mind a spare set.  However, I'd like know that they are a quality exact reproduction before invest the money.
Wagons and Rancheros do not use the same rear moldings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2025 at 2:45AM
Okay Vince, I hear that. Now help me find the right part numbers for a wagon with the wide trim. I have seen just one to pull the quarter trim from, and that was around 25 years ago. Those were scarce decades ago.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2025 at 1:11PM
1972 Wheel Moldings.
Front Moldings
Full Moldings for Torino 2-door without side trim, and all Rancheros
D2OZ 16038- A (right)
D2OZ 16039- A (left)
Half moldings for all Torinos with side moldings and all wagons
D2OZ 16038- B (right)
D2OZ 16039- B (left)
Rear moldings
Full Moldings for Torino 2-door only
D2OZ 6529164-A (right)
D2OZ 6529165-A (left)
Half Moldings for all Torinos with side trim (2-door and 4-door only)
D2OZ 6529164-B (right)
D2OZ 6529165-B (left)
Half Moldings for Wagons only
D2OZ 7129164-B (right)
D2OZ 7129165-B (left)
Full rear moldings Ranchero only
D2OZ 9729164-A (right)
D2OZ 9729165-A (left)
Of note, although 4-door cars did not have full moldings from the factory, they would fit the 4 door cars. The new no differences in the wheel openings between the 2-door and 4-door.
1973 Wheel Moldings (full moldings only)
Front:
Front Moldings
Full Moldings for Torino 2-door without side trim, and all Rancheros (note it's a different part number from 1972)
D3OZ 16038- A (right)
D3OZ 16039- A (left)
Rear moldings
Full Moldings for Torino 2-door only (note that is the same part number as 1972)
Edited by 72FordGTS - 07-July-2025 at 1:43PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2025 at 1:49PM
Rear moldings
Okay, that's great detail for part numbers. But that is added confusion, I thought the 4-door and wagon had the identical rear wheel well and quarter trim.
What could be different about those two sets of trim? The numbers being different suggests the wheel wells are not the same shape either. If that is correct, I will need to know which 1972-1976 rear wheel well matches the Ranchero.
The part numbers suggest the 2-door rear trim might work for me if the Ranchero rear wheel well matches the 4-door cars, and not the wagons. I'd bet the match will be to the wagons. I wonder if any pictures might show the difference between a 4-door and a wagon?
I did test fit the actual side molding pieces, but not the polished 2-door wheelwell trim I got from eBay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2025 at 2:37PM
Does anyone know the differences for the variety of years?
I want to make sure when contacting them that they understand the some years are different from others. They state "72 and up" but IIRC, 73 fronts are different, and 74 up are as well. Rears, I don't recall any discussions on these.  (Only referring to full wheel lip, not the side trim variants)
Can anyone offer any insight into this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 24-June-2025 at 3:48PM
The 1972 front fender opening is not the same shape as the 1973-1976 fenders, so they simply will not swap.  These 1972 front full wheel lip moldings were only used a laser stripe 2-door Torinos.  Despite what we see today, laser stripe cars were far less common that the standard side trim, hence the rarity of this moldings.
That said all Rancheros that had wheel lip moldings used the full length moldings for 1972.  So the repro company needs to know that this molding is usable on all 1972 Torinos and Rancheros.
The rear quarter panels on the 2-doors/4-doors have the same wheel opening through out the 1972-76 years.  However, there were differences in the molding.  So all will physically fit regardless of it they are correct or not.  Some 1974-76 cars have rocker moldings and/or fender trim and the ends of the wheel lip moldings were flattened for these other moldings.  This same thing was done on the front moldings, which is why the 1973 Laser stripe moldings are often different from the 1974-1976 ones.  There were also other variations, such as moldings for the cars with fender skirts.
So when this company is making these moldings, they will want to reproduce the 1972 laser stripe moldings.  Those are the ones people want and the hardest to find.  They may need to get an example to create it.  Id' be more than happy to give more info or help in anyway.  I am not willing to remove mine from the car but I'd be happy to take measurements.
There is more info in these threads I just found.
Wagons and Rancheros each have their own part numbers for the rear quaters.  So there must be some minor differences in the rear quarters that would justify a separate part number.  I don't know what it is, but they appear to be close enough to adapt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 25-June-2025 at 4:04AM
motion to start an Authoritative Wheel Arch Moulding Thread or is that already a thing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 25-June-2025 at 4:30AM
Thanks again for the details about the various trim. I thought I had figured out which pieces I needed, I'm going to put the wide trim on my one Ranchero, which was never done. It is apparent that the rear wheel wells don't match all the others, but logically they will match one. I'm betting now that it'll be the wagon wheel wells, so I'll have to find a pair of the trim from the 72-76 wagons.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 25-June-2025 at 6:33AM
For your ranchero, I have doors forward for you if you're ever in the Dallas area. Right now they are in my shed, just waiting for me to damage them...(The ones off my car.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 25-June-2025 at 6:34AM
Additional NOTE:
You can be added to their list by using their contact form.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 26-June-2025 at 1:57PM
Pete, do you want me to relay some of this info to them?
And yes Rockatansky, this can be made to be the official wheel trim thread.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 26-June-2025 at 2:01PM
If you would like.
I did email them last night to see if they needed further details, but I have not heard anything back. More noise wouldn't hurt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2025 at 1:38AM
I emailed them and provided the basic information and part numbers of the correct moldings. We will see what happens.  I hope this works out.  I looked a some of their other wheel lip moldings repros and they look to be good quality.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2025 at 6:47AM
Joel from Metro obsolete called me today to ask a bit about the wheel lip moldings and would like to obtain a set.
He stated that they are moving along with the tooling, but only has a later set. (74 up with rocker molding).
Anyone have a set to assist? Or should i Purchase a set and send them.
THoughts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2025 at 3:45PM
Are you able to find a 1972 full molding set for sale?  If you are willing o purchase and send them in,  it would be awesome of the Torino community.
Maybe Joe Lombardo (ublovedford) has a set he could send them but we'd have to contact him off the forum as he rarely comes on here anymore.
I will share the info on some FB groups, and hopefully that will help build some interest.
Edited by 72FordGTS - 27-June-2025 at 3:51PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2025 at 12:02AM
I messaged Joe, he has a set, he is going to get me some pictures. I also reached out to a couple of others. If I can get a set at a halfway decent price, I will purchase them. BTW, thanks for posting to the FB pages.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2025 at 5:23AM
I have someone in Illinois wanting to trade me a set of nice moldings, but needing to find out if they are '72 or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2025 at 6:58AM
They texted me that they think they have lined up a set.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2025 at 1:14PM
Ok, keep us posted and let me know if there is anything I can help with. I do have an original set but they are on my car.
Lyonsjo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lyonsjo Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2025 at 6:18AM
I have a very used set that I took off the 1972 q code fastback that I'm restoring. I would also like to pre-order a set.
Regards,
Johnnie Lyons
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2025 at 6:54AM
Regards,
Johnnie Lyons
Pete is saying they might have a set but I am sure he can chime in and let us know if they could use yours.
Call 9123830172 to reserve a set
Jesse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jesse Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2025 at 7:20AM
I would like to be added to the list for the wheel moldings for 72-74 Gran Torino. I know there's two styles one if you don't have rockers and one if you do . Looking for the ones that have the rocker panels. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote peter.jenerette Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2025 at 8:55AM
You need to contact them, you can go to their website or call them above
rrlcommish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrlcommish Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2025 at 7:43AM
That's probably me.  I talked with Joel on Saturday and I am going to loan him mine.  They are a bit beat up but very solid for them to use as a template.
1972 Gran Torino Sport Fastback, Bored 30-over 351C - 4V, Lt Blue, Pertronix Ignitor, dual exhaust with Turbo mufflers, otherwise stock
Post Options Post Options   Thanks (1) Thanks(1)   Quote rrlcommish Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2025 at 7:44AM
That was likely me he was referring to.  I talked to Joel last Saturday at the FCA Nationals and I am going to loan him mine.  They are a little beat up but still in good shape to use as a template.
This page was generated in 0.124 seconds.
