  New Posts New Posts RSS Feed - Upholstery and cushions for seats
Smalz12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smalz12 Quote  Post ReplyReply Direct Link To This Post Topic: Upholstery and cushions for seats
    Posted: 21-September-2025 at 10:11AM
I have bought the upholstery to redo my 75 ranchero seats. The cushion on the passenger seat looks to be good and able to reuse. The drive seat is shot. I have been researching where to get cushions/foam and everything is pointing me towards a craft store or somewhere that sells foam. I found a website called “Aliexpress” that sells seat foam. It is just a block of foam, not shaped.
I’m hoping for suggestions on where to get foam? How much I may need? Pointers on how to shape it into the correct size. Also, what tools do you suggest getting to install the upholstery?
Sak7788 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sak7788 Quote  Post ReplyReply Direct Link To This Post Posted: 21-September-2025 at 12:53PM
    The tools are called hog rings and hog ring pliers.
   I was going to try using memory foam from a mattress topper it can be trimmed carefully with a razor blade, there's a guy on YouTube that goes thru the steps below.
And
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 28-September-2025 at 5:20PM
Harbor Freight has the hog ring kits.
This page was generated in 0.090 seconds.
