  New Posts New Posts RSS Feed - Distributor caps
Distributor caps
1973gts View Drop Down
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Topic: Distributor caps
    Posted: 30-September-2025 at 3:05AM
This is probably a simple topic but one I don't know the answer.  The distributor cap that was on my car when I purchased it was a two part, an adaptor and a top cover.  I have since put a newer cap on it and am wondering what the purpose of a two part cap is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2025 at 6:34AM
There is a YouTube video that explains it, and also shows how you can go back to the smaller cap by removing the spacer.  As they explain it, it’s simply to allow a for a hotter/bigger/stronger spark that doesn’t run the risk of cross-firing to a wrong lead. I’ll see if I can find that.  It was on a videoe about the Dura-spark vs. points…….
CobraJoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CobraJoe Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2025 at 10:22AM
1968 Torino GT F Code
'96 Bronco,
'39 Ford Coupe,
'57 Fairlane, SOLD
2025 F150 SuperCrew,
2025 Edge Platinum
Post Options Post Options   Thanks (1) Thanks(1)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2025 at 2:15PM
Don’t know if this is the same one that CobraJoe posted…..but here’s the one ai referred to——
[edit: - Ok, so…….I checked— it’s not the same one, but it’s by the same guy. The one that I posted is more about the fallacy of the cross-fire claims.  But, if you go to EITHER video, you get the info, and you can go to the guy’s list of videos and watch the rest of them, too.]
Dfox
Status: Online
Post Options Post Options   Thanks (1) Thanks(1)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2025 at 3:04PM
Thanks to both of you for the info, I've been chasing a dying while driving issue lately and wanted to make sure I didn't need the two part distributor cap.  I have just located the probable problem, a cracked bare wire on the distributor pickup assembly.  The videos do a good job explaining the cap situation.
