'72 Outside air duct |
Post Reply
| Author | |
jglover
Joined: 05-June-2024 Location: California Status: Offline Points: 53 |
Quote Reply
Topic: '72 Outside air ductPosted: 28-November-2025 at 7:57AM |
Does anyone have a picture or diagram of the driver side outside air duct. The cable on mine is frozen and I would like to pull it down and get it working. I would like to know where all of the mounting screws are so that I am spending minimum time under the dash. Not easy being old!
1973gts
Joined: 05-March-2018 Location: Grand Rapids Mi Status: Online Points: 720 |
Quote Reply
Posted: 28-November-2025 at 2:09PM |
I have a 73 but I believe it's the same as the 72. I have two pics that will hopefully assist you.
![]() The vent cable handle is mounted to the underside of the dash with I believe 2 screws. ![]() Second photo shows the cable as it runs just to the side and above the fuse box where it attaches to a metal bracket with not sure if one or two bolts. The cable end then attaches to the vent lever but I can't quite remember what secures it. Hope this helps.
1973gts
Quote Reply
Posted: 28-November-2025 at 2:19PM |
There is an NOS cable on Ebay with a pic that shows the end of the cable.
![]() I believe the cable end just slides onto the vent lever and a cap slides onto the end of the vent lever.
Quote Reply
Posted: 29-November-2025 at 2:36AM |
Let me know if you want me to try and dig up the factory diagrams or not.
jglover
Quote Reply
Posted: 30-November-2025 at 5:14AM |
This is exactly what I needed. Thank you.
1973gts
Quote Reply
Posted: 30-November-2025 at 6:38AM |
jglover
Quote Reply
Posted: 17-December-2025 at 2:41AM |
The square end that hold the handle was bent. A little hammer work and some WD40 and it work fine. Thank you again.
1973gts
Quote Reply
Posted: 17-December-2025 at 2:44AM |
Post Reply
| Tweet |
