  New Posts New Posts RSS Feed - Spindle backing plate question
The Torino Kid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Torino Kid Quote  Post ReplyReply Direct Link To This Post Topic: Spindle backing plate question
    Posted: 17-January-2026 at 5:50AM
Hello, I am aware the spndles are differernt after 1973 because of the bearing size. But my question is
"Are the disc brake backing plates the same for the 3 bolt mounting flange regardless of the year?"
I need to get replacements and I want to get the correct ones.
Thank you
Edited by The Torino Kid - 17-January-2026 at 6:02AM
1973 Gran Torino Sport CJ 351
'Q' code 63R body
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-January-2026 at 9:56PM
  i believe they are
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 12-February-2026 at 7:00PM
Not sure, but I believe the spindle duct pieces are the same for a lot of the 72-79 spindles.
Post Options Post Options   Thanks (1) Thanks(1)   Quote The Torino Kid Quote  Post ReplyReply Direct Link To This Post Posted: 16-February-2026 at 5:05AM
So I pulled the ones off my 73 and bought some from a 75 ranchero. the only differnce is the 73 GTS version has an extra cut-out for air cooling.
thank you all for the input!Clap
'Q' code 63R body
This page was generated in 0.099 seconds.
