  New Posts New Posts RSS Feed - 69 Ranchero/Fairln loose column shifter
jimh1956 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimh1956 Quote  Post ReplyReply Direct Link To This Post Topic: 69 Ranchero/Fairln loose column shifter
    Posted: 04-February-2026 at 3:57AM
My 69 Ranchero column shifter is loose and won't stay in park or neutral. Is there a known cause/solution? Thank you. jh
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 06-February-2026 at 9:14AM
Have you checked the detent in the column for wear?  Check over the linkage and the pin that holds the shifter in place too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimh1956 Quote  Post ReplyReply Direct Link To This Post Posted: 08-March-2026 at 7:13AM
Thank you for the reply. I don't know that my column has detents, will check. Shift handle pin was previously replaced to include shoulder brass bushings. All of the plastic bushings have now been replaced, special tool was needed. The cross link had a plastic bushing on the frame side that was trapped in the welded assembly, now replaced by a brass bushing and re-welded. The special tool resembles the Ford Manual tool, except has keyhole type slots on both jaws of the vise-grip plier. I will attempt to attach sketches.
This page was generated in 0.127 seconds.
