  New Posts New Posts RSS Feed - Package Tray and Sail Panels
twerth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twerth Quote  Post ReplyReply Direct Link To This Post Topic: Package Tray and Sail Panels
    Posted: 04-February-2026 at 6:21AM
I'm working my way through the interior of my 69 fastback, and I've made it to the back of the car. My package tray and sail panels are in rough shape, so I'm hoping for ideas on how to make them presentable.
My package tray evidently saw some water at some point, so it's warped and it's crumbling in a few places around the edges. The pictures below don't do the damage justice. Reproductions for these are hard to find and expensive when you do. Shipping costs are worse, so I'm going to try to salvage this one. My plan is to dampen the back/bottom and then put some weight on it until it dries. Then, I might try to patch in new material in the worst of the edge damage. Once that's done, I'll wrap it in new vinyl that will match the seats. Let me know if this sounds like a good plan or if you have better ideas.
As bad as the package try is, the sail panels are worse. Years ago, someone had replaced the originals with plywood cut outs. These were wrapped with what appears to be headliner material, but it's in really poor shape. I'd like to use these as patterns to make a new pair out of Masonite, but when I hold them in place in the car, They don't look like they fit. I'd prefer to save the cost of repros, so I'm wondering if there are patterns (electronic) out there somewhere I could use? As an alternative, I might use the plywood panels to create cardboard templates that I can easily manipulate until I get a fit I'm happy with. Again, any suggestions are welcome.
Thanks!
1969 Torino GT
1968 Cougar XR-7
CobraJoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CobraJoe Quote  Post ReplyReply Direct Link To This Post Posted: 04-February-2026 at 6:53AM
I have one, I paid $100 for it, just not sure how to get it to you if you were interested? I bought it because it was identical to the old one that was in the trunk of my car, not realizing that it wasn't for a formal roof.
1968 Torino GT F Code
'96 Bronco,
'39 Ford Coupe,
'57 Fairlane, SOLD
2025 F150 SuperCrew,
2025 Edge Platinum
Post Options Post Options   Thanks (0) Thanks(0)   Quote twerth Quote  Post ReplyReply Direct Link To This Post Posted: 04-February-2026 at 11:41AM
I'd be interested, but shipping's a killer. I'll take a shot at repairing mine, and if that doesn't work out, I'll have to come up with plan B.
1969 Torino GT
1968 Cougar XR-7
Post Options Post Options   Thanks (0) Thanks(0)   Quote CobraJoe Quote  Post ReplyReply Direct Link To This Post Posted: 04-February-2026 at 11:45AM
I'll be at  Carlisle if that helps?
Tell me about it, shipping on mine was $119
'96 Bronco,
'39 Ford Coupe,
'57 Fairlane, SOLD
2025 Edge Platinum
Post Options Post Options   Thanks (0) Thanks(0)   Quote twerth Quote  Post ReplyReply Direct Link To This Post Posted: 05-February-2026 at 1:22AM
Trying to get it flattened out. I dampened the backside, and I'll let it sit like this for a couple of days. Fingers crossed.
1969 Torino GT
1968 Cougar XR-7
spriegel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spriegel Quote  Post ReplyReply Direct Link To This Post Posted: 05-February-2026 at 11:46AM
I wrote a "how-to" article on how I replaced my rear package tray:
Fairview, PA
'1973 Ford Gran Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote twerth Quote  Post ReplyReply Direct Link To This Post Posted: 06-February-2026 at 2:12AM
Thanks Spriegel. For some reason, the pictures in your thread aren't coming through.
Reading the procedure though, I think I did something very similar a couple of years ago on my Cougar. I actually bought a sheet of Masonite and cut out a new tray using the old one as a pattern. I didn't pad mine, but that's just because I didn't think of it.
Unfortunately, the fastback won't be that simple. It has a curve at the back that I can't recreate from flat Masonite. I'll continue to work on the old one, and I'll post some pictures of my progress (if there is any).
1969 Torino GT
1968 Cougar XR-7
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 06-February-2026 at 9:10AM
It seems your photos in your thread were deleted from your files.  If you are able to upload them again, I can fix the thread.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twerth Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2026 at 2:11AM
I've got it fairly well flattened out. Far from perfect, but a lot better than it was. I don't know if this is the right answer, but I'm using fiberglass to repair cracks and patch in damaged areas. Once it's solid again, I'll recover it and run it for awhile.
1969 Torino GT
1968 Cougar XR-7
benzesrule View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote benzesrule Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2026 at 3:18PM
I made my sail panels out of white lexan panels, then glued on the material. They won't warp.
Phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote twerth Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2026 at 2:12AM
All done. Not perfect, but not too shabby. Definitely good enough for who it's for. First picture is some of the fiberglass repair I did on the backside and around the edges. I tried to minimize the work on the top so it would be as smooth as possible.
Sanded the edges and smoothed the top as needed and then covered it with 1/8" EVA foam. Unfortunately, I didn't take a picture of that. I followed the foam up with marine vinyl I got off Amazon. The vinyl came folded instead of on a roll, so I have some creases that show a little. Not bad, and maybe they'll disappear or minimize over time. There are also some waves in the board, but 100% better than before.
Now on to the sail panels. That should be a little simpler.
1969 Torino GT
1968 Cougar XR-7
Post Options Post Options   Thanks (0) Thanks(0)   Quote CobraJoe Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2026 at 2:14AM
Nicely Done!  Thumbs UpThumbs UpThumbs Up
'96 Bronco,
'39 Ford Coupe,
'57 Fairlane, SOLD
2025 Edge Platinum
Post Options Post Options   Thanks (0) Thanks(0)   Quote spriegel Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2026 at 2:42AM
Hi Vince,
Are you able to fix this?  Otherwise I can see if I still have the photos.
I didn't delete any photos, so I'm not sure what happened?
Thanks,
Fairview, PA
This page was generated in 0.188 seconds.
