  New Posts New Posts RSS Feed - Tires & wheel sizes
Tires & wheel sizes
guilf1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote guilf1 Quote  Post ReplyReply Direct Link To This Post Topic: Tires & wheel sizes
    Posted: 05-May-2004 at 12:48AM
Anyone know how wide of a tire can go on a 7" wheel? Is a 245 too wide?
Also, 8" and 10" wheel.
Thanks!
Nemtorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nemtorino Quote  Post ReplyReply Direct Link To This Post Posted: 05-May-2004 at 4:58AM
Size
Serv. Desc.
Load Rating
UTQG Max
Load
Max.
Inflation
Press.
Tread
Depth
Rim
Width
Range
Meas.
Rim
Width
Sect.
Width
Tread
Width
Overall
Diam.
Revs
Per
Mile
BFGoodrich Radial T/A
175/70SR13  82S    SL    360 A B
1036lbs.
35psi
12/32nds
4.5-6"
5"
6.9"
5.2"
22.6"
920
195/60SR13  83S    SL    360 A B
1080lbs.
35psi
11/32nds
5-7.5"
6"
7.9"
6.3"
22.2"
937
185/70SR14  87S    SL    400 A B
1201lbs.
35psi
12/32nds
4.5-6.5"
5.5"
7.4"
5.5"
24.3"
856
195/60SR14  85S    SL    400 A B
1135lbs.
35psi
11/32nds
5-7.5"
6"
7.9"
6.3"
23.2"
897
205/70SR14  93S    SL    400 A B
1433lbs.
35psi
12/32nds
5.5-7.5"
6"
8.1"
6.1"
25.2"
825
215/60SR14  91S    SL    400 A B
1345lbs.
35psi
11/32nds
5.5-8.5"
6.5"
8.7"
7"
24.2"
860
215/70SR14  96S    SL    400 A B
1554lbs.
35psi
12/32nds
5.5-7.5"
6.5"
8.6"
6.4"
25.8"
806
225/60SR14  94S    SL    400 A B
1455lbs.
35psi
11/32nds
6-9"
6.5"
9"
7.2"
24.7"
842
225/70SR14  98S    SL    400 A B
1675lbs.
35psi
12/32nds
6-7.5"
6.5"
9"
NA
26.5"
785
235/60SR14  96S    SL    400 A B
1565lbs.
35psi
11/32nds
6-9"
7"
9.5"
7.6"
25.1"
820
245/50SR14  93S    SL    400 A B
1433lbs.
35psi
11/32nds
7-9.5"
7.5"
10"
8"
23.7"
878
245/60SR14  98S    SL    400 A B
1675lbs.
35psi
11/32nds
7-8.5"
7"
9.8"
8"
25.6"
813
265/50SR14  98S    SL    400 A B
1642lbs.
35psi
11/32nds
7.5-10"
8.5"
10.9"
8.6"
24.5"
849
195/60SR15  87S    SL    400 A B
1190lbs.
35psi
11/32nds
5-7.5"
6"
7.9"
6.3"
24.2"
860
205/55SR15  87S    SL    400 A B
1201lbs.
35psi
11/32nds
6-8"
6.5"
8.4"
6.6"
23.9"
870
205/60SR15  90S    SL    400 A B
1301lbs.
35psi
11/32nds
5.5-8"
6"
8.2"
6.6"
24.7"
842
215/60SR15  93S    SL    400 A B
1411lbs.
35psi
11/32nds
6-8.5"
6.5"
8.7"
7"
25.2"
825
215/65SR15  95S    SL    400 A B
1510lbs.
35psi
11/32nds
5.5-7.5"
6.5"
8.7"
7"
26"
800
215/70SR15  97S    SL    400 A B
1620lbs.
35psi
12/32nds
5.5-7.5"
6.5"
8.6"
6.4"
26.8"
776
225/60SR15  95S    SL    400 A B
1521lbs.
35psi
11/32nds
6-9"
6.5"
9"
7.2"
25.6"
813
225/70SR15  100S    SL    400 A B
1753lbs.
35psi
12/32nds
6-8"
6.5"
8.9"
6.7"
27.3"
762
235/60SR15  98S    SL    400 A B
1642lbs.
35psi
11/32nds
6-9"
7"
9.5"
7.6"
26.1"
797
235/70SR15  102S    SL    400 A B
1896lbs.
35psi
12/32nds
6-8.5"
7"
9.3"
7"
27.8"
748
245/60SR15  100S    SL    400 A B
1753lbs.
35psi
11/32nds
7-8.5"
7"
9.8"
8"
26.6"
782
255/60SR15  102S    SL    400 A B
1885lbs.
35psi
11/32nds
6.5-10"
7.5"
10.2"
8.2"
27.1"
768
255/70SR15  108S    SL    400 A B
2183lbs.
35psi
12/32nds
6.5-9"
7.5"
10.1"
7.6"
28.9"
720
265/50SR15  99S    SL    400 A B
1720lbs.
35psi
11/32nds
7.5-10"
8.5"
10.9"
8.6"
25.5"
816
275/50SR15  101S    SL    400 A B
1830lbs.
35psi
11/32nds
7.5-11"
8.5"
11.2"
8.9"
25.9"
803
275/60SR15  107S    SL    400 A B
2149lbs.
35psi
11/32nds
7-9.5"
8"
11"
8.9"
28"
743
285/70SR15  115S    SL    400 A B
2679lbs.
35psi
12/32nds
7.5-9"
8.5"
11.5"
8.5"
30.8"
675
295/50SR15  105S    SL    400 A B
2061lbs.
35psi
11/32nds
8-11"
9.5"
12.2"
9.5"
26.7"
779
195/50SR16  83S    SL    400 A B
1074lbs.
35psi
11/32nds
5-7.5"
6"
7.9"
6.3"
23.7"
878
205/50SR16  86S    SL    400 A B
1168lbs.
35psi
11/32nds
5.5-8"
6.5"
8.4"
6.6"
24.1"
863
205/55SR16  89S    SL    400 A B
1279lbs.
35psi
11/32nds
6-8"
6.5"
8.4"
6.6"
24.9"
835
225/50SR16  91S    SL    400 A B
1367lbs.
35psi
11/32nds
6-9"
7"
9.2"
7.2"
24.9"
835
245/50SR16  96S    SL    380 A B
1576lbs.
35psi
11/32nds
7-9.5"
7.5"
10"
8"
25.7"
809
265/50SR16  101S    SL    400 A B
1797lbs.
35psi
11/32nds
7-9.5"
8.5"
10.9"
8.6"
26.5"
785
275/65SR16  111S    SL    400 A B
2403lbs.
35psi
10/32nds
7.5-9"
8"
11"
8.9"
30.1"
691
295/50SR16  107S    SL    400 A B
2149lbs.
35psi
11/32nds
8-11"
9.5"
12.2"
9.5"
27.6"
754
73ranchero View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73ranchero Quote  Post ReplyReply Direct Link To This Post Posted: 09-May-2004 at 10:21PM
I guess the rule of thumb is, rim with and add 2 inches ie. 7 inche rims can take up to 9 inch tires. If you want a good stance to it try 235/60 15s front 275/60 15s rear. and yess you can fit a 10 inch rim under a 72 Torino, Ranchero all the way to 79.
This page was generated in 0.140 seconds.
