  New Posts New Posts RSS Feed - Instrument cluster changeout ...
Fordified V8 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fordified V8 Quote  Post ReplyReply Direct Link To This Post Topic: Instrument cluster changeout ...
    Posted: 24-November-2009 at 2:19PM
Does anyone have any insight regarding an instrument cluster changeout?
70 MACH I "R" code
72 GTS 351CJ
72 TR6
15 F250 Lariat
ramair351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ramair351 Quote  Post ReplyReply Direct Link To This Post Posted: 24-November-2009 at 2:25PM
i'm in the middle of one. take the top pad off. look for screws at he front edge and on the sides towards the doors.    drop the shifter into 1st gear and take off the black cluster bezel after removing about 8 more easy screws. then you will see how the cluster comes out. be careful the white plastic is fragile.
-Pete
1972 montego GT
1970 Torino cobra SCJ
1970 mustang mach 1
1965 Falcon futura
Post Options Post Options   Thanks (0) Thanks(0)   Quote ramair351 Quote  Post ReplyReply Direct Link To This Post Posted: 24-November-2009 at 2:26PM
sorry you have floor shift, disregard the shifter comment.
-Pete
1972 montego GT
1970 mustang mach 1
1965 Falcon futura
GranTorinoMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoMan Quote  Post ReplyReply Direct Link To This Post Posted: 24-November-2009 at 2:44PM
The easiest way to take it out is remove your top dash pad and the front cover which are held by screws. You can reach in from up top to disconnect the Molex Plug and unclip the speedo cable.
You'll need this Molex Plug with the Sport Gauge Cluster, make sure it all comes as a package when you buy your Sport Gauges.
Edited by GranTorinoMan - 24-November-2009 at 2:56PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fordified V8 Quote  Post ReplyReply Direct Link To This Post Posted: 24-November-2009 at 2:51PM
sweet mural GT Man, thanx
70 MACH I "R" code
72 GTS 351CJ
72 TR6
15 F250 Lariat
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 25-November-2009 at 6:11AM
OK, stupid question, isn't the red wire with yellow hash marks a resistance wire?
I know in the main harness going up to the dash, there is a wire coming off the firewall block that must not be cut.
I spent way to many hours piecing back my harness so it was good. Then I had to go and do something stupid like add extra power circuts and move wiring around.
DOH
Post Options Post Options   Thanks (0) Thanks(0)   Quote ramair351 Quote  Post ReplyReply Direct Link To This Post Posted: 25-November-2009 at 6:36AM
the resistance wire goes from the ignition switch to the firewall  i think it was yellow/red
-Pete
1972 montego GT
1970 mustang mach 1
1965 Falcon futura
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 25-November-2009 at 7:03AM
THe red and yellow wire should just be the power wire for the cluster, 12v+ with ign and start. I'll try to take a pic of my FSM when I get home from work.
SquireCJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SquireCJ Quote  Post ReplyReply Direct Link To This Post Posted: 25-November-2009 at 10:09AM
Here is an excellent tech. link on the '72-'79 Gauges.
http://www.ranchero.us/forums/showthread.php?t=8411
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoMan Quote  Post ReplyReply Direct Link To This Post Posted: 25-November-2009 at 5:41PM
It doesn't get any better than that, talk about detail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoMan Quote  Post ReplyReply Direct Link To This Post Posted: 25-November-2009 at 5:45PM
That Ranchero forum has some dedicated owners, extremely thorough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fordified V8 Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2009 at 11:48AM
thanx for that, I actually came across it recently. very thorough.
there are a couple of holes in it, just trying to see if there are
any hidden nightmares.
70 MACH I "R" code
72 GTS 351CJ
72 TR6
15 F250 Lariat
This page was generated in 0.194 seconds.
