  New Posts New Posts RSS Feed - Rear end housing inspection plug install
Blue71GT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue71GT Quote  Post ReplyReply Direct Link To This Post Topic: Rear end housing inspection plug install
    Posted: 16-October-2011 at 6:15PM
I have a 70 Torino with the 8 inch rear end. I want to install an inspection plug on the back side of the housing so I have to drill a hole and tap it. Do I need anything on the backside to support the plug or will it seal enough when I tap it with a pipe tap. Reason for doing this is I don't have access to a 9 inch right now and have a 3.25 gear set out of a 63 Fairlane,  It doesn't have the fill plug on the third member.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 17-October-2011 at 1:36AM
I'm going through this with my 77 Cougar. I was just going to bolt it together, leave an axle out, jack the car up so that axle was in the air, and fill the axle through the axle tube, lol.
75GranMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 17-October-2011 at 12:48PM
I wouldn't just tap the housing.i believe I've seen a weld in plug/sleeve assy.or I know it was either jeep or a dodge product that used a rubber push in plug.
lynchster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 17-October-2011 at 3:56PM
Doesn't yours have a "fill" on the center section either?
72 Gran Torino Sport
13 Taurus SHO "Mr Pig"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue71GT Quote  Post ReplyReply Direct Link To This Post Posted: 17-October-2011 at 8:06PM
The only other thing I could do is drill and tap the center section housing so its normal like the regular ones or 67' and up. The axle housing seems a little thing to just tap and put in a plug though.  Thought about filling it through the vent tube too but that might take awhile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 18-October-2011 at 1:31AM
OEM does.. but the center chunk I have from a 79 'swap meet rear axle with rear discs' does not.
ramair351 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ramair351 Quote  Post ReplyReply Direct Link To This Post Posted: 18-October-2011 at 2:33PM
i have filled thru the vent before, it can be done
-Pete
1972 montego GT
1970 Torino cobra SCJ
1970 mustang mach 1
1965 Falcon futura
stanman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanman Quote  Post ReplyReply Direct Link To This Post Posted: 18-October-2011 at 2:55PM
How did you know when you had enough? Did you add a pre-measured amount or...?
orlnslloyd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orlnslloyd Quote  Post ReplyReply Direct Link To This Post Posted: 18-October-2011 at 4:12PM
The housing is too thin to tap. Can't even get one thread in it.
'72, GTSFB, 460, C6, 3.70
dvldog2513 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dvldog2513 Quote  Post ReplyReply Direct Link To This Post Posted: 19-October-2011 at 1:50AM
you need to drill the hole and weld in a drain bung like this.just need to make sure it's steel        http://www.rjracecars.com/Drain-Plug-and-Bung-204101-Prodview.html
Bennie
1972 GTS Q Code
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 19-October-2011 at 2:59AM
What about one of those "add-a-drain' kits they sell for transmission pans.. Could do the housing with it on the back.
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 19-October-2011 at 8:31AM
+1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blue71GT Quote  Post ReplyReply Direct Link To This Post Posted: 21-October-2011 at 8:33PM
Thanks for the idea's, know how much an 8 inch takes? 2 or 2.5 qts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 27-October-2011 at 3:05PM
 I checked with my jeep bud and he says jeep uses a rubber plug.IMO this is the fastest/ cheapest way to go.
Grande Verde View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grande Verde Quote  Post ReplyReply Direct Link To This Post Posted: 28-October-2011 at 4:06AM
http://www.jegs.com/i/JEGS+Performance+Products/555/60136/10002/-1Here is what I am using for a filler
Edited by Grande Verde - 28-October-2011 at 4:08AM
Harry
72 GTS 351W
02 F-350 7.3 PSD
This page was generated in 0.098 seconds.
