taurus |
Robbdtme ![]() Senior Member ![]() Joined: 06-June-2012 Location: Central WI Status: Offline Points: 765 |
![]() ![]() ![]() ![]() ![]() Posted: 28-September-2012 at 6:33AM |
This has the 3.8. Reg distributer single cam single coil. Kind of ruled out timing chain or overhead timing belts coil packs no crank sensor on it. Starts and idles perfect and does rev at first then sputters and rpm drops. After a few seconds even matted to the floor rpms are maybe 800-1300 only with major exhaust smoke. Limp Mode usually uses multiple coil packs and fires alternating cylinders at least the ones I am familiar with. Anyway thanks for the replies probably be tinkering some more on it this weekend. Looking like I will be flying out to Florida for work next week so hopefully figure it out before then.
At least the other half has been having fun driving the F150 king cab long box 4x4 5.4 triton to work lately, She has a 70 mile round trip and the truck gets 8-10 mpg but no squeeking yet about 28 bucks in gas a day . Edited by Robbdtme - 28-September-2012 at 6:35AM |
Johnny cash Special 74-75-76 freak. 77 XR7. 78 LTD II sport looks pretty but poop 302 in it.
fordpower ![]() Senior Member ![]() Joined: 02-September-2010 Location: willseyville,ny Status: Offline Points: 1738 |
Don't know about ford but my van has a sensor that goes into limp mode when something is wrong.It will run around 15mph till you get it to the garage. It was crank case sensor or something on the fire wall I had to replace.
The real ford part worked her blinkers are back. Now yesterday she called and said it was making a noise and will not go over 15mph. Found the noise which was a electrical sensor egr related something to the tune of a exhaust pressure sensor but from reading unrelated to the loss of power. Even in neutral it revs to 4000 rpm for about half a second then rpms drop fast and lots of exhaust smoke. After a fews hours checking everything I have a feeling the fuel pressure is low although that was about the only thing I had not checked as I had hung up looking at it by that time last night. She loves the car, Myself I will personally love to hit the crush button on it at the junkyard.... |
ghosttrain2 ![]() Member ![]() ![]() Joined: 05-July-2011 Location: Northern Nevada Status: Offline Points: 46 |
my "98 windstar with a 3.0 seized the engine when the cam sensor quit turning because the drive gear had worn out. Evidently some of these engines don't oil the drive gears. This engine had about 98,000 on it. No warning, the check engine light came on when it failed, and was too late.
1977 LTD, 2 door
1972 N code Ranchero, Project 1972 Torino formal roof 1970 Torino 500, Project 1974 Cougar parts car |
unlovedford ![]() Senior Member ![]() ![]() Joined: 17-December-2010 Location: Tennessee Status: Offline Points: 10142 |
THAT'S FUNNY!!
Trying a ford part vs a fleabay generic one today. one of my best friends owns a huge junkyard here so picked a few off off Ford Taurus's. Told here she now has a Furcury Table.
75GranMan ![]() Senior Member ![]() Joined: 05-April-2011 Location: Colchester, CT Status: Offline Points: 1225 |
Are you sure you got the correct switch?the most common problem with this set up is dust settles down in the multifunction switch,and when you use the hazards and then try to shut them off,it screws up the circuitry for the signals.try taking an air hose and blow air around the hazard switch while rapidly pushing the hazard switch on and off.then try and see if the signals now work.most of the time I can get them working again withhout installing a new switch.Tricks of the trade,let me know how ya make out.John
Other half has a Sable that about every other week something craps out. Latest is the blinkers stopped working and this one has me so far. Hazzards were also out. Brake lights work fine and blinkers and brake lights are on the same fuse. Changed flasher unit ( Special 3pin deal ) Hazzards work fine now no blinkers. All bulbs good.OK no biggie right changed Steering multifunction switch same thing hazzards no blinkers. Grabbed to meter and checked voltages. Hazzards on flasher circuit normal 12 volt blinkers on flasher only 7 volts WTF? Guess the next step is to look up the ignition switch circuit and see if it has a seperate circuit when key is on to power blinkers switch could be dirty/bad? causing the voltage drop to 7 from the proper 12
converter seals like to puke when they get warm/hot don't leak as bad cold/cooler.
well first taurus went 200,000 mi and eng broke. this on only 103,000 and trans is pushing fluid out of somewere.
MXBrougham ![]() New Member ![]() Joined: 06-December-2009 Location: Wichita Falls T Status: Offline Points: 23 |
My 88 MT-5 runs, but needs CV joints, a MAP sensor, and the climate control panel is completely dead. I understand the ignition switch (the flaming one) is the cause of that. So I need a new one of those. Of course I only paid $250 for it back in '04. So I'm pretty well satisfied. Plus no tranny issues since it's a 5-speed. I like it anyway. Of course I have 11 other cars to use too.
I liked my 99 had 198,000 before daughter broke the motor. This 07 has 98,000 and just don't feel as good.
Loved those Yamaha V6 engines. My '95 was white with grey leather - great sleeper. The '93 was Arrest Me Red with tan leather. Couldn't have picked a worse color SHO to build. However, while the heads were off, we polished the intake and valve covers and detailed the non-chrome hardware with red highlights. What a beautiful massive engine. Even stock, they were a sight to behold - in case anyone has never seen one.
72GTS351CJ ![]() Senior Member ![]() ![]() Joined: 30-November-2010 Location: NY Status: Offline Points: 1475 |
I had a 93 sho. The only problem I had was a heater core and an idler pulley. It had 150k miles when I sold it and it was still running strong
72GTS Clint Eastwood Special
Hmmm. I liked every Taurus and Sable I ever had. Maybe just my luck or that I got good ones...
'90 Sable (bought in '92 and kept in family 4 years - outstanding highway car) '86 5speed 4 cyl Taurus - good basic car that ran, gave it to a friend. (2) '92 Sables bought in '94 - kept 1, sold the other, great car '95 SHO - This car would make you feel like Superman, felt like I lost a pal when I sold it. Still miss it. '93 SHO - chipped, head work, exhaust, SVT parts - scary fast, knew I better sell it before it got me a ticket. '89 Taurus - bought for $50, spent $50 for repairs, sold it, lady still driving it. '95 SE Taurus - nice highway car, 3.8 engine ran well. '95 Frankenwagon - Taurus wagon with a 5.7 Vortec, 700R, 9 inch. Ran and drove, but all of us were scared to trust it on the road. Horrifically fast and dangerous. Completely our fault it ever existed, and decided to dismantle it so no one got hurt. Cannot blame Ford for that one. |
AFTER THREE WEEKS i GOT THE POWER WINDOWS TO WORK.i HAD REPLACED THE WRONG RELAY.
fordnmerc ![]() Senior Member ![]() Joined: 21-May-2003 Location: Watkins Glen NY Status: Offline Points: 875 |
My wife had a 98 Taurus. What a nightmare. Leaked oil, leaked gas, transaxle was going bad....just endless. I would rather have a Maverick, Fairmont, or Granada than one of those damn things.
David
if it's the 2v engine check the timing cover for seeping, drips on the cat and usually evaporates before it leaves any spots on the ground.but head gaskets can be done in a day.(equipped shop)
73Torino ![]() Member ![]() Joined: 30-October-2011 Location: Waterloo IA Status: Offline Points: 140 |
I think the head gasket might have gone out on my 02 Taurus, antifreeze keeps disappearing but the oil looks completely fine. Grrrr...
1973 base model Torino
GTW ![]() Senior Member ![]() ![]() Joined: 21-January-2012 Location: SC Status: Offline Points: 5780 |
Yeah I would part it out and scrap what's left. |
1973 Gran Torino station wagon 1971 Maverick 2 Door Retired 60s NHRA Anglia |
kversch ![]() Senior Member ![]() Joined: 02-December-2009 Location: New york Status: Offline Points: 1399 |
the north east winters took a tole on this one, if the sub structures weren't so gone we probably wouldn't be scraping it out. we were jacking it up and the jack whent right threw everything and stopped at the floor.
-kevin-
Brown 72 gran torino 351c 2v Black 73 GTS FB 302 Red 73 GTS FB 351C C6 trans 73 GTS FB Parted 73 torino 4dr, 302, FMX parted 97 F250 crew cab 7.3 diesel http://kverschtorino.blogspot.com/ |
You don't see a lot of first gen Sables much anymore. |
i got a 98 mercury sable basically the same car. about ready to cut it up for scrap and maybe sell a few parts off.
-kevin-
The only decent one is the SHO.
ilyes ![]() Senior Member ![]() ![]() Joined: 09-January-2010 Location: Philadelphia PA Status: Offline Points: 3782 |
I hate taurus, I had to swap many engine on those, and countless head gaskets.
What the hell was ford thinking. Flex joint gone bad on my07.Ford has no replacement only new cat.1175 plus inst.anybody ever found a way to fix it.
