  New Posts New Posts RSS Feed - catalytic converter nut size
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Topic: catalytic converter nut size
    Posted: 03-March-2012 at 7:24AM
OK guys, time for my stupid question of the week...
Was over working on the Torino this morning and the task of the day was to drop the exhaust out from under it. Got her all up on the jack stands and roll under her with tools in hand to remove the nuts holding the exhaust H pipe to the converters ('76 460). The 1/2" socket was too small, so I put the 9/16" socket on the ratchet extension and got ready to put my all into it to break it loose only to have the socket slip on the nut. Thought perhaps it might have been a metric nut but no suck luck. So my question is:
Is the nut holding the H pipe to the converters 17/32" or have they eroded?
Thanks for your help!!
kenneth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenneth Quote  Post ReplyReply Direct Link To This Post Posted: 03-March-2012 at 7:50AM
I wouldn't know the nut size, but the threads may have exhaust cement on them too, along with rusted on ??
Might need to use one of the reciprocating saws mentioned here in another thread
1973 Q code sports roof
75GranMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 03-March-2012 at 12:09PM
I believe the nuts to be 5/8 originally.make sure your using a 6 point socket.nuts are probably rusted away,try a metric socket that fits snuggly,you might have to tap the socket onto the nut.heating the nuts will  help greatly and or soaking them in weasle piss(penetrant oil).
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2012 at 4:14AM
John,
Got 'em soakin! 99% sure it was a 9/16 nut I was using but I'll bet you are right that it was a 12 point. I'll have to check and get the appropriate style. They aren't too rusty but like kenneth suggested might have something on them to prevent loosening.....
Thanks guys!
stanman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stanman Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2012 at 5:54AM
I think they've probably rusted away a bit and now they're "between" sizes. I try to always use 6 point sockets, especially on something that's rusty or hard to get started. If you can give them a "whack" with a hammer and cold chisel it might help break them loose too. If all else fails, a nut splitter has helped me on occasion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2012 at 6:01AM
LOL, yeah I was just looking at those!
Thanks Stan...
This page was generated in 0.122 seconds.
