  New Posts New Posts RSS Feed - Spot Weld kit for MIG welder's
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: Spot Weld kit for MIG welder's
    Posted: 11-April-2012 at 5:23AM
saw this in the Eastwood Catalog then looked online for more info and this is pretty kewl
if you have a MIG Welder with Tweeco Nozzle you can use this kit.
Eastwood welders and I know Lincoln's have the Tweeco style Nozzle,not sure what other brands
Doesn't require drilling holes like when you plug weld,but can use it if you do have holes such as when you drill the spot welds on a used part and want to weld it to your car.
Watch the video in the link
Spot Weld Kit
Edited by 72 GTS 429 - 11-April-2012 at 5:26AM
