  New Posts New Posts RSS Feed - FLOOR SHIFTER
FLOOR SHIFTER
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Topic: FLOOR SHIFTER
    Posted: 06-September-2006 at 6:17AM
Question:
Where do you cut the hole for the floor shifter?
I have the floor pan exposed and it is not obvious at all there it goes...
Webmaster
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 15-August-2006 at 4:52AM
Does anyone know where to get the C-6 version of the shift lever in the transmission? All I have ever found was the C-4 version...
Webmaster
Torinogts73c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Torinogts73c Quote  Post ReplyReply Direct Link To This Post Posted: 10-August-2006 at 1:00AM
Yes you need to change the shift lever on the trans. as well as it is opposite of the column shifter. Gary
Gary 73 Gran Torino Sport 351CJ,SVT LIGHTNING,07 CHARGER R/T HEMI,97 Mustang GT Vert
"Never complain Never explain"
tjbooker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tjbooker Quote  Post ReplyReply Direct Link To This Post Posted: 09-August-2006 at 11:59AM
HELP, DO ANY OF YOU GUYS KNOW,
IM CONVERTING MY 74 TORINO FROM COLUMN SHIFT TO FLOOR SHIFT,
I HAVE A SHIFTER AND THE FMX SHIFTER ROD. I READ SOMEWHERE THAT A SHIFTER ARM IS ALSO NEEDED BESIDES THE ROD AND SHIFTER BECAUSE THE
SHIFTER ARMS ARE DIFFERENT THAN ON COLUMN SHIFTERS. ANYONE KNOW?
THANKS TJ
