  New Posts New Posts RSS Feed - Cleveland decode help?
72 Torino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 Torino Quote  Post ReplyReply Direct Link To This Post Topic: Cleveland decode help?
    Posted: 15-June-2012 at 12:00PM
Hi.
Can someone help me decode what my cleveland engine block is? Casting nr: D2AE-CA and 3E1 and it has 2V heads.
Thanks.
Kim
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2012 at 3:11PM
if it has 2v heads it's probaby a 2v  H code motor as they used the same casting number on the 351CJ 4v block and the block got drilled for 4 bolt main caps.only way to tell if it is 2 bolt main or 4 bolt main is by pulling the pan off as both engines used the same casting number
Robbdtme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbdtme Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2012 at 3:19PM
1972 to 1974 block. All had the same block casting number those years. 351C 2V, Boss 351C, 71 CJ, HO 72-74 4V. Some blocks were machined for 4 bolt mains and some 2bolt.
3=the year the decade is assumed in this case it means 1973
E=the month A =jan b=feb c=march and so on but the letter j is ommited because it looks to much like a 1
1 = the day of the month
3E1 = may 1 1973
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 Torino Quote  Post ReplyReply Direct Link To This Post Posted: 22-June-2012 at 2:14PM
Thanks for your help here guys.
Kim
This page was generated in 0.119 seconds.
