trans |
fordpower
Senior Member Joined: 02-September-2010 Location: willseyville,ny Status: Offline Points: 1763 |
Posted: 03-January-2011 at 11:43AM |
c4 c6 trans,do they detach from bell housing or are they one unit.
occupant
Senior Member Joined: 23-October-2006 Location: Lawton, OK Status: Offline Points: 1973 |
c4 and fmx detach, c6 does not
08 Explorer EB, 195K, for the wife still looking for another something |
fordpower
Ok. has anyone ever changed from a ford 3speed auto. 77-79 mid size to a aod trans. I have a aod in a 302 pinto,would like to but it in one of my ltd2s.
occupant
There's a few considerations for that. I plan to put an AOD into my car at some point and I've been told I need to do the following to swap from an FMX to an AOD:
shorten driveshaft about an inch linkage should fit ok but might need new bushings kickdown rod goes away, replace with Lokar AOD cable make sure converter matches pilot hole on crank make sure converter bolts to flexplate* flip transmission mount upside down it should clear the crossmember ok you have to change the front yoke on your driveshaft to an AOD one cooler lines may be different sizes, like 1/2 or 5/8, use adapters or rubber line at the trans end if you care about the column shifter indicator, just rub off the letters and print your own don't forget to plug/remove the vacuum line since AOD's don't have a modulator *or use flexplate for 351W/AOD Crown Vic, has to be 28oz balanced not 50oz like a late 302 that's all I know...SO FAR...still learning more every day |
fordpower
Thanks nothings simple. ltd2s are both 351w with ford 3speed auto what ever that is.All I know is they are solid units.the aod is in a 303 pinto I have no idea about it.
Thanks again till spring bob |
