Transmission cooler setup |
Post Reply
| Author | |
72RogerGT
Joined: 20-September-2013 Location: Maricopa, AZ Status: Offline Points: 233 |
Quote Reply
Topic: Transmission cooler setupPosted: 16-December-2014 at 9:58AM |
Hi guys I'm getting to the the point that I need to setup the trans cooler and I have no idea as to how to connect trans radiator n cooler to each. Any ideas would help out a lot. Sorry I am still new at this. I have read a thread regarding which order to connect them yet it didn't explain how to do so.
GranTorinslo
Joined: 09-June-2007 Location: United States Status: Offline Points: 54 |
Quote Reply
Posted: 16-December-2014 at 11:40AM |
You want to have the hot line from trans goes to radiator, radiator to external cooler, external to trans. I believe the line in at the top of the radiator is hot and bottom is return/cold. So the bottom line gets moved/altered/routed
Edit: add appropriate amount of fluid Edited by GranTorinslo - 16-December-2014 at 11:42AM |
72RogerGT
Quote Reply
Posted: 16-December-2014 at 3:24PM |
Thanks appreciate it I actually found some fittings that might work just right.
Post Reply
| Tweet |
