  New Posts New Posts RSS Feed - transmission leak 302 ci
dutchman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dutchman Quote  Post ReplyReply Direct Link To This Post Topic: transmission leak 302 ci
    Posted: 28-December-2010 at 9:21AM
Hello Torino members,
A couple of months ago i bought a 1972 Ford Torino 4 doors. It has a common 302 ci ford motor. When i looked under the car and saw that there where drops of fluid lying under the car. The drops where red what indicated that it was transmission fluid. The drops came from the gear lever at the left side, i think its the gear lever but i dont know for sure?
Has anyone had this problem and how did you solve that?
i am sorry for any spellingerrors.
greetings from Holland
ilyes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ilyes Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2010 at 9:53AM
it's pretty simple, you just have to drop off the pan, valve body, unbolt th shifter lever, you pull it from the outside and change the seal, it takes 30 minutes Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2010 at 10:26AM
it could also be the kickdown shaft leaking, it doesn't require dropping the pan
the kickdown shaft fits through the selector shaft and is sealed with an O ring (or two) behind the arm that the nut holds on
C4 trans?
Edited by Rockatansky - 28-December-2010 at 10:34AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dutchman Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2010 at 9:37PM
Thank you very much for the info. I am going to look arround voor the o-ring ore a seal. The parts are not so easy to find here in the Netherlands. Is there anyone that has specs ore technical drawings (don't know the right word) ford a ford 302 v8 5.0 liter block and the c4 tranmission? thank you very much!
greetings!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2010 at 9:57PM
here's one but it doesn't give great detail of the selector shaft seal
the one labeled lever seal is the O ring that i mentioned. it's just a common O ring that can be matched up by size. the selector shaft is a 'metal clad seal', # 36072 here,
Edited by Rockatansky - 28-December-2010 at 10:10PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dutchman Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2010 at 10:05PM
Thank you very much. I am loving this site allready. Big smile
greetz
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2010 at 10:10PM
