  New Posts New Posts RSS Feed - Trunk floor trunk gutter
72ftcj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72ftcj Quote  Post ReplyReply Direct Link To This Post Topic: Trunk floor trunk gutter
    Posted: 15-October-2023 at 5:05AM
Hi everyone I just bought a 72 gran torino cobra jet car and have some rust. I need to repair the lower trunk gutter does anyone know what new piece would be close and could work. Also need to replace the trunk floor with new any ideas on that also thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 19-October-2023 at 1:26PM
It is not reproduced.  You would have to fabricate a new gutter or get a good piece off a parts car.
Compton View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 19-October-2023 at 4:02PM
Chopper used one from a 1976 Holden Torana hatch when he repaired mine…was almost identical but required a small amount of modification…can easily be sourced from Rare Spares in Aussie….
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2023 at 9:47AM
Typically, most guys chop donor panels off parts cars. Compton, thanks for the post on this. Always helpful to know.
A lot of panels have to be fabricated off other models/brands to make something work.
Basic example: trunk floor, use a reproduction panel, something for a 70-72 Chevelle or Oldsmobile Cutlass to make something work. Other times, like wheel houses, I used late 60's mustang outer wheel houses, pie cut to fit the Torino quarter panel wheel opening shape and welded up.
Hot rodding mantra: #chopcutweld
Edited by Eliteman76 - 12-January-2024 at 1:49PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 31-December-2023 at 10:23AM
Show us what section you need, and how long/short you need .... some of us might have enough shorter sections to complete it.
Dave Fox
This page was generated in 0.127 seconds.
