  New Posts New Posts RSS Feed - undercoating
undercoating
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: undercoating
    Posted: 20-February-2012 at 8:24AM
What is the best way to get rid of undercoating.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2012 at 8:35AM
propane torch and a putty knife.. or a heat gun in lieu of a torch.
The residue will come off with liberal amounts of brake kleen.
Keep the brake kleen away from the torch!
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2012 at 8:48AM
Don't ever try to grind it off, no matter how dry it appears. You will be deeply sorry. Trust me.
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2012 at 10:21AM
i've used a die grinder with wire wheel but it makes a mess but sometimes it's easier then trying to scrape it all. I do try to scrape off what I can but in some areas scrapers just don't work too good and that is where the power tools come in handy
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2012 at 10:52AM
i "ground" mine off with a drill and a wire wheel.  the stuff is tar... it was obliterated but alot of the particles stuck to my face and would NOT come off.  i walked around for a week looking like a reverse raccoon.  (because i was wearing safety glasses)  but it got the job done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2012 at 1:05PM
tTHANKS,TRIED GRINDER WHAT A MESS .Kerosene slow and messy.Try heat gun next,gess its just going to be slow mess.
kversch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kversch Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2012 at 1:12PM
torch and a putty knife,   the stuff melts right off,   if your not careful you will catch it right on fire.   its messy stinky and not a fun job no matter how you do it.
-kevin-
Brown 72 gran torino 351c 2v
Black 73 GTS FB 302
Red 73 GTS FB 351C C6 trans
73 GTS FB Parted
97 F250 crew cab 7.3 diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2012 at 1:35PM
TO be honest....... if it's been on for 30 years, and there is no rust at the seams, I can't see removing it.
Zebra 3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zebra 3 Quote  Post ReplyReply Direct Link To This Post Posted: 21-February-2012 at 12:51PM
  Has anyone ever removed the undercoating only to find hidden rust(under the undercoating)?   Just trying to come up with a plan before I even think of doing this....I understand that rust "could" form from the other side that is not "coated"
  I don't want to do a frame off restoration(at least not now or in the fore seeable future), but I do want to do as much as possible to protect and preserve everything.
Henry Ford. 1926
Brian Conn
'76 Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 21-February-2012 at 2:09PM
You can usually tell where rust would be under 30 year old undercoating. Look for 'bubbling'. Or rust at the seams of the panels. That's where it would be.
I'll get flak for it (Cough Andy Cough) but I did a quick look for major rust and then just blasted everything with undercoating. I only Zero Rust (like POR15) coated things that bolt on, like suspension components.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2012 at 6:55AM
This stuff is on the inside of the engine comp.It appears someone rust proofed the whole thing then someone painted over it.
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2012 at 7:03AM
oh yucky,what a mess
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 22-February-2012 at 11:15AM
And then some.
