Upper ball joints |
Markb73gtorino ![]() Member ![]() ![]() Joined: 23-September-2018 Location: Corpus Christi Status: Offline Points: 78 |
![]() ![]() ![]() ![]() ![]() Posted: 20-October-2018 at 11:00AM |
Hello all,
Ran into an issue, upper ball joints appear to be riveted in. How do I get them out? There was one nut I could remove but they are still in solid. I will work on the lowers while I wait for an answer. Thanks Mark |
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14566 |
grind the heads of the rivets off! new ones come with bolts and nuts to attach them
oh and you may need to drive them out with a punch and hammer....after the heads are removed
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5654 |
Like John says you can use a hammer and a punch. Or an air chisel with a punch type head is helpful if you have one to drive the rivets out once you cut the heads off. Once the rivets are knocked out you can remove it.
