Using a DC to AC inverter |
n2fordwagons ![]() Senior Member ![]() Joined: 20-July-2013 Location: GA Status: Offline Points: 2252 |
![]() ![]() ![]() ![]() ![]() Posted: 15-December-2014 at 1:59PM |
I know nothin' 'bout 'lectricity. :)
I've got a Christmas tree on the roof of my wagon that I'm going to haul around for the Holidays. I wanna run some Christmas lights on the tree, using an inverter. The box for the lights says they're rated at 175 Watts. And I want to run two strings of them, together. So, first question, would I need an inverter that's rated at continuous 350 Watts? Second question, is it safe to connect something like this to the cigarette lighter of my Montego wagon? Any input is greatly appreciated.
Jeff
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14560 |
jeff, i've never used one but that's supposedly what they're for, you say the lights are rated @ 175 watts, is that the actual wattage draw? if so then i'd say yeah 350. can you find ones that are LED? as they draw WAY LESS power, now that i'm thinking about it--watts my be the output of lights, amperage is the power draw
alex, ain't you an electrician??? chime in here! Edited by californiajohnny - 15-December-2014 at 4:09PM |
They're the big C9 bulbs, like in the old days. I was wanting to use them. Figured they'd look good with the '76 wagon.
Jeff
unlovedford ![]() Senior Member ![]() ![]() Joined: 17-December-2010 Location: Tennessee Status: Offline Points: 10142 |
They make LED C9 sets now. We have them out front in the shrubbery. Work pretty well and are resistant to vibration - something to consider. However, I am old school as well, so we have a 4th tree with OLD bulbs on it. Round snow speckled, pearl bulbs, bubble candlesticks, tinsel melters, etc. Lots of heat, and we don't leave it unattended, LOL.
Very cool idea on the tree wagon. |
Jeff
GranTorinoSport ![]() Admin Group ![]() ![]() Admin of "The Org" Joined: 20-May-2003 Location: Seattle Status: Offline Points: 2287 |
So if you needed 350 Watts of power, at 12V (or let's say 14.4V, which is more of a standard for auto power), we come up with 24.3A. Now, knowing that the cigarette lighter is rated for 15A, you would instantly blow a fuse.
That same 350W of power at 110VAC is like 3.2A power - significant difference. My point being, that Christmas light string is waaay to much for the power outlet - you'd need to hard wire the inverter into the battery or something similar. Just out of curiosity, I was poking around Amazon at power inverters. For a 500W energizer model, at max output it draws 54A, which is a ton of juice, when you consider that original alternators that came in earlier models could be as low as 45A! |
Webmaster |
Thanks Scott! That's what I was afraid of. I might try to spread one string of lights over the tree, and see if I can get by with that, using a lower wattage inverter.
Jeff
Be sure to keep it moist, lest you lose a lot of needles and/or go flying down I-85 with a burning tree on top, LOL.
That is SO Griswald!!! PLEASE tell me the tree will be UPRIGHT while you drive down the road!!! ![]() Modern Led lights are CHEAP, draw little power (battery operated in some cases), and much less/no heat generated.
Ranchero Fan ![]() Senior Member ![]() ![]() Joined: 03-March-2011 Location: Chicago area Status: Offline Points: 1022 |
Put a tree topper on it, wired/ plugged into the trailer aux plug, then you''ll have, a one of a kind highmount brake light
Brian 1973 Ford Ranchero Big Block. ''THE OTHER WOMAN''
I ended up going with some C9 LED lights. Enjoy!
Jeff
bdaugette ![]() Senior Member ![]() ![]() Joined: 02-December-2013 Location: United States Status: Offline Points: 259 |
That is so cool. I guarantee you will get the looks from other, less fortunate, car owners!!!
Bill Daugette
72 GTS 351C 4V |
