  New Posts New Posts RSS Feed - valve cover gasket leak
jimka111 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimka111 Quote  Post ReplyReply Direct Link To This Post Topic: valve cover gasket leak
    Posted: 21-November-2021 at 4:48PM
after 3 new gaskets it still leaks oil i have 351 Windsor(76 Torino )  any ideas welcome my email is jameskoehler2002@yahoo.com both regular and cork gaskets have been tried!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2021 at 5:11PM
   Dimple the bolt holes up with a ball peen hammer and a block of wood if stock covers. Done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimka111 Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2021 at 6:09PM
how thick is the block of wood and how many strikes?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2021 at 7:56PM
any piece  like 1x4 or 2x6 lay the wood down on the bench now turn the valve cover upside down so you're looking at the inside where the valves and oil would be, lay the edge by a bolt hole on the wood, hit the hole area with a couple taps of a hammer, making the hole flat againWink do this to each hole! if its a stock steel coverWink don't do this to cast aluminum!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 21-November-2021 at 8:18PM
this was the only video i could find showing dinging it back down....
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimka111 Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2021 at 5:22PM
thank you turned out to be power steering hose spraying on valve cover go figure that one new it was leaking but didn't know how much till a year later thanx again
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2021 at 6:48PM
 Shocked
Post Options Post Options   Thanks (0) Thanks(0)   Quote Inkara1 Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2021 at 6:54PM
Sure glad that didn't cause a fire!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimka111 Quote  Post ReplyReply Direct Link To This Post Posted: 26-November-2021 at 7:00PM
it could have thanx for the reply now i  have to try to clean the stain off the fender due to to smoke halfway there  sure looked it was going to be on fire with the amount of smoke
