valve cover gasket leak |
jimka111
New Member Joined: 07-October-2013 Location: Milwaukee,WI Status: Offline Points: 39 |
Posted: 21-November-2021 at 4:48PM |
after 3 new gaskets it still leaks oil i have 351 Windsor(76 Torino ) any ideas welcome my email is jameskoehler2002@yahoo.com both regular and cork gaskets have been tried!!
handsofstone
Dimple the bolt holes up with a ball peen hammer and a block of wood if stock covers. Done.
jimka111
how thick is the block of wood and how many strikes?
any piece like 1x4 or 2x6 lay the wood down on the bench now turn the valve cover upside down so you're looking at the inside where the valves and oil would be, lay the edge by a bolt hole on the wood, hit the hole area with a couple taps of a hammer, making the hole flat again do this to each hole! if its a stock steel cover don't do this to cast aluminum!
this was the only video i could find showing dinging it back down....
jimka111
thank you turned out to be power steering hose spraying on valve cover go figure that one new it was leaking but didn't know how much till a year later thanx again
Inkara1
Senior Member Joined: 17-November-2021 Location: Ridgecrest, CA Status: Offline Points: 285 |
Sure glad that didn't cause a fire!
jimka111
it could have thanx for the reply now i have to try to clean the stain off the fender due to to smoke halfway there sure looked it was going to be on fire with the amount of smoke
